What have you done to your 100 Series this week? (18 Viewers)
What intake manifold have you got there?
Certainly does not look like the manifold on mine.
I was thinking the same thing, figured it was a supercharger but didn’t see the usual pulley and chocked it up to “ too expensive for me to need to recognize”
TRD Engine cover. Previous owner put it on there. I might trade it for a standard one.
I've got a very low mileage standard engine cover I'd trade you for... ;)
Sounds good. Hopefully it fixes that weird whhrrrrr noise.
I promise it will - plus, you'll be able to save a bunch of money buying non-premium fuel! I'm really quite the life saver in this situation.
I did not see the drive pulley in the photo…
Does it drive off of a separate belt? Or does it drive off of the serpentine belt?
How much boost does that produce?
What size injectors did you change to?
My OCD might be kicking in. I swapped out some of the front lights, stuck LaminX amber on the light I didn't swap out and it's triggering my OCD.
Also, I swapped in some Teqcustom retrofit headlights. They sent me some DEPO corner lights, and I had to do some de-pinning and re-pinning of the existing connector to fit the DEPO corner light connectors. Wasn't aware of all that until I received them, and had to jump on MUD to research!
Maybe 8-9psi. Not sure on injector size but I am running the 9th AND 10th injectors in the S/C vs just having one (9th)
Maybe close to 400hp +\- Unichip tune, XAT Racing pulley kit. Gates RPM belt. Doug Thorley Headers and Exhaust. Needs a better tune and dyno. Will do that after stability snorkel and air box from total Fabrications arrives.
