Soon, I’m gonna drive it....really I am.
It was a lot of work but the front end is nearly rebuilt. A new (not rebuilt) Toyota steering rack, new tie rod ends, new control arms, bushings, bolts all of it.
There are several well documented pain points. The rusted in LCA bushings, the coolant when you take off the oil filter housing, the fussy bolts for the oil filter housing.
It all worked eventually but I ended up having a frozen hose return side hose fitting. A new one is on the way.
Approaches used on the pain points:
LCA’s, hole saw 1 1/2” thru as much of the bushing as possible then turned a compression thru bolt 5/8 x 8” and washers till they broke.
Then I used a sawzall to cut a slot in the bushing. I pressed in frozen bearings with the same bolt and some monster sockets a buddy had. One socket setup pushed the rim in 95% of the way then the other one was bigger than the whole diameter and allowed the busing to seat all the way.
The coolant hose is just messy and dumps unless you want to try and compress it thru the inner finder. I didn’t since I was unsure if the age of the hose.
The oil filter housing bolts come out with a stubby wrench and then a swivel on 12” of extensions.
View attachment 2061400View attachment 2061403
