What have you done to your 100 Series this week? (33 Viewers)
Gamiviti spare tire mount system. I first saw these at HIH8. Finally got one.
Mounted. I really like it, but note the mounting bracket is not a direct fit to the fuelpax mount, supposed to work with Rotopax tho. I had to do a bit of fab.
Replaced front brake pads, sway bar links, lubed chassis and detailed the interior.
While doing my brakes, I noticed there is up and down play on the DS steering rack bushing. The bushing looks fine? Can I just torque it down or is that bushing done?
It was pretty easy. My ‘02 LX470 came with a 15 pin connector. The new radio came with connectors for the standard Toyota plugs. I bought male Toyota plugs and wired them to a Metra adapter that plugs to the 15 pin connector. Now everything is plug and play.
This is the radio I used, bought it last year though
Amazon product ASIN B07H8C4PRX
View attachment 2087233View attachment 2087234
So this unit is no longer available:( How did you find this replacement? Trying to figure out one to replace it w/ but can't find or I just don't know how to select one. Thanks!
Nomination for the worst directions from a large company goes to
ARB for the 100 series bumper.
Total s*** show. Do yourself a favor and find a good write up on Mud to follow.
6 hard head scratching hours later
Ready to get into the same, finished installing winch to the bumper yesterday night.
Put the rubber things on before you put it on the truck. That was left out of instructions and I can’t get bottom nuts on
Also, install the lights before you put the bumper on and skip the bolt that goes in (drill) through the light hole. 6 is plenty
Yeah I know. I measured it numerous times when adjusting the TBs. You should have seen it before, it was waaay worse. I’m going to drive it around for a week or so and remeasure and adjust as needed. There’s plenty of turns left where I indexed them so it won’t be too big of an issue.
That rake looks crazier than Ikarus' and his he said is a 1-3/4" difference. That definitely looks way more than an inch.
Installed some Old Man Emu 2865 rear coil springs and cranked my front torsion bars. All other suspension components left stock.
A few more pictures in my build thread.
After
Before
Important Numbers (Driver / Passenger)
Old Front: 18.75" / 19"
T Bar Turns: 7 / 5
New Front: 20" / 20"
Front Increase: 1.25" / 1.00"
Front Wheel Suspended: 23.25" / 23.25"
Droop: 3.25" / 3.25"
Old Rear: 20" / 20.25"
New Rear: 21.75" / 21.75"
Rake: 1.75" / 1.75"
Important Question:
Is my 1.75" rake too much for daily driving? Will I see anything negative come from this? We test loaded the back with gear and the rake becomes closer to 1.25" as the rear springs compress.
I could crank the torsion bars a little more but I really want to avoid CV boot issues.
Thanks in advance for the feedback.
The springs will settle some over the first couple of weeks. My 864’s sure did. Wait a couple weeks, then see where it settles in. Rake will be fine. Too much t-bar without a diff drop and you’ll get cv vibration.
After 20 years, my truck's white paint had become pretty dull.
Spent a few hours working on the exterior and did the following:
-Sanded small chips and gashes that developed a little rust with a fiberglass pen
-Painted spots with Dupli-Color Scratch Fix All in 1
-Applied Meguiar's Ultimate Compound to revitalize old paint
-Applied Nu Finish polish
More pics on my build thread.
Only problem with making your paint look good is that your trim and bumpers look terrible by comparison!
About to attempt to fix my hood flutter. The auto body foam has a 10 second work time, so its gonna get sporty.
Mines got major flutter on the highway, makes people think its open. Were you following a write up you found or just replacing weatherstripping?
I'm definitely in the same boat. After one week on the new rear springs, I'm down from 1.75" of rake to 1.5". If it stays there, I'm happy. If it eventually settles to 1.25", even better.
Thanks for the heads up. I already installed rubber covers. Will do the lights too. Seems the provided bracket works well for your control box. Mine is a warn VR, bracket does not fit that
Removed, greased, and replaced front sway bar bushings to stop an obnoxious creak from the front end. Quick lap around the block and still creaking. :bang:
Any radio made to fit the standard 200mm wide Toyota radio size should fit.
I bought mine last year. Actually bought two, one for my other car first then I liked it so much I bought another to put on my 80 but ended up putting it on the 100 instead. I really like the dual knobs on it. Make sure to get an Android radio that has at least 8 cores and 4GB of RAM.
