What have you done to your 100 Series this week? (37 Viewers)
Did the master cylinder rebuild on my 01. but the rear brakes have no pressure to bleed them so I think the Brake booster is done as well. The ABS solenoid is also clicking. Time to save allot of money I guess....
Surprise 2 month marriage gift....
I wonder if she will notice?
Search here, there is a place in Santa Ana, Ca that sells re-manufactured booster for $285 plus shipping.
What size tires are you running? This is the route Im thinking of going. Got any pics?
I’m running Falken Wildpeaks 285 75 16s. Got a little of the stink bug back with the 865’s but hoping it’ll settle after a bit. Regardless, I’m super happy with the ride.
Porter can I bug you for the exact link? I just hopped on amazon and I thiiiink I see the one you got "Lily's wood" but I want to triple check the application and color you got. Your wheel wrap is hands down the cleanest and best fitting I've come across.
Absolutely. Remember, you can email the seller to give them a detailed request on where, or if you would like perforation.
Loncky Steering Wheel Cover 98-07
1998 LC, 336k miles
I put in a new Spectra Premium radiator. It was a bit more fiddley than I had hoped, but I got it done. Also had to get new valve stems installed since the local tire guys didn’t replace them when I mounted my Wildpeaks last week.
Next up, new OEM shocks front and rear with all new bushings front and rear.
Well I started to work on the new leather for the front seats last night that I purchased from LSeat. After a really long evening I eventually finished with one seat at around 1:30am. There is definitely a learning curve to this process. I'm about 95% done. I broke a tab on the back cover so I'll need to fix that and for some reason I can't get the recliner motor to work. But to be honest I'm not sure if it worked before I took it out either. As I disassemble the drivers side I'll have to check to see which connection goes to that switch and go back and recheck the passenger side again.
Here's the results....
Before
After
Great way to start the weekend! I got my old smashed up factory bumper off and installed the Dobinson's rear. So far so good, but I haven't had it farther than around the block. I still have to wire up all the lights, and install the jerry can swing out.
Turned 160k so I changed the oil / filter and sent a sample to Blackstone (I change at 10k intervals).
Ever since I bought my LC nearly two years ago the top door/compartment on my center console did not latch. I had a strap holding it to the second door/hatch to keep it closed. I had been looking to buy another upper section and replace, but all options were $$$. So I came up with my own solution that was nearly zero $. I bought a magnet latch off of Amazon and some rivets at the hardware store.
And less than 10 minutes later......
Works perfectly. $13 ish for the latch and rivets. Saved myself about $137 compared to my other options.
I finished the extension of my DIY sleeper platform. After having the cargo section installed for a week or so, I’m thinking it might be a permanent fixture. This thing is super handy! Leave all my daughters softball stuff underneath and still have the top for all the everyday stuff. You know, kids backpacks, groceries, and all the other super cool family crap. :hillbilly:
I also found a Lund Catch All rear floor mat on Amazon for $28 with Prime shipping. It’s a little darker than the factory carpet and it does move a bit, but it’s going to work fine for the price.
Looking good! Are you at 450k yet?
I am thinking about the 2500 ARB as well....might need some pointers!
Text me when your ready to pull the trigger, it’s a great set up.
It is helpful to have another person to set it up. Both installing and when deploying it.
Although a 2000 looks short on a Cruiser IMHO.
