What have you done to your 100 Series this week? (51 Viewers)
He upgraded the bulbs to led.
JUST TO CLARIFY BUT ARE YOU SAYING YOU JUST REPLACED THE BULB FOR $30 OR THE HEADLIGHT FOR $30 AS STATED IN FIRST COMMENT?
In the picture I have the LED bulb. I said headlight because the 9006 is our headlight bulb. I will correct myself, 9006 is lowbeam bulb I replaced.
Installing 2865's.
What is your Kings set up? I'm looking to do some desert running.
King shocks from filthymotor sports desert dune valving setup basically means much heavier rebound damping
Sway bar delete front and rear
Tough dog torsion bar 30% more spring rate
Total chaos upper control arms extended travel shocks
Als
o forgot to mention king liner springs in the rear 2 inch lift.
+ remover front differential and axels for better weight distribution
Als
which color did you go with on your stock rims and was it duplicolor?
I went with a Ford color (RC)- I've used it before. I had them professionally painted, but they're not holding up so well from the gravel roads. I'll have them powdercoated next. (as the spare is)
Over the last month I have been getting ready for Mardi Krawl. OEM cv axles, SPC UCA, new ball joints, rebuilt motor for brake pump, Trail Tailor diff drop, upper and lower differential arms, Metal Tech upper and lower adjustable rear control arms, Tough Dog adjustable panhard bar, new sway bar bushing, and Trail Tailor extended front and rear sway bar links.
