What have you done to your 100 Series this week? (51 Viewers)
P0135 popped up. 160k miles. Replaced both upstream sensors while I was in there and did a capacitive discharge after installing to reset adaptives.
Used a 22mm crowfoot, kinda fiddly. I have an o2 sensor socket but couldn't find it with 5 mins of looking.
Amazon, $40 each, 2344169 Denso. My friend works at Denso, it's the exact same part off the same line, same spec. Toyota's parts department doesn't check them when they come in to their depot.
Installed OEM front mud flaps, then got new shoes after finding a deal I couldn't resist at Discount Tire Direct. I wound up with 275/70r18 (33.2") BFGoodrich All Terrain T/A KO2s.
Edit: Below is a link to the tire deal, which is $100 off of $400, plus free shipping and no tax. Since they do an auction for only 2 tires, you can use the coupon twice if 2 tires cost $400+. I wound up calling my local Discount Tire store and asked if they could beat the price, and they did. I was out the door for $850.
tires, wheels items in Discount Tire Direct store on eBay!
Had this little upgrade installed by the great folks at ACC Garage in Atlanta. AHC override switch. Also alignment as I plan to run in high exclusively.
Installed OEM front mud flaps, then got new shoes after finding a deal I couldn't resist at Discount Tire Direct. I wound up with 275/70r18 (33.2") BFGoodrich All Terrain T/A KO2s. View attachment 1152311View attachment 1152312
Great deal on a great tire ( my opinion ) . I opted for the 285/65/18 but kind of wish I would of went with these . Looks great !
Added Spidertrax spacers front and rear along with Rock Warriors and BFG AT's. Tomorrow morning I'll check pressures on Techstream, adjust torsion bars and trick the sensors into Hi mode.
Sent from my iPhone
Sent from my iPhone
Sounds great ..Lets see it!
A week after installing ARB combo bar I rechecked the gaps and centering . Gave all the bolts a crank and called it good . Began the install of the IPF dual beems . image.jpeg image.jpeg
Brand new shafts both sides. Blew the PS CV on the trail last weekend. Figured best option since the Both had been rebooted so it was just a matter of time.
View attachment 1141877View attachment 1141878
Nice Pics ! I need to replace the aftermarket cv/axles that the previous owner installed. They shake and are sub-standard It looks like you put factory OEM replacements in. Can I ask how much those would cost ? I will have to replace both sides/units. Thanks in advance !
Rolled over 170k on my way to Whitaker Point/Hawksbill Crag in the Ozark Nat Forest
replaced my 18" chrome lexus rims and 285s with 16" OEM in black, with 285 duratracks
Looks great. And, I like the company you keep ;)
I helped one friend dynamat his 62 last weekend, and this past weekend, we removed a leaf spring. I also helped the guy with the gold LX behind mine change out his radiator. I've been putting in some sweat equity and learning a lot.
I was over having carpet on the tailgate, but wanted something padded and that wouldn't take on water. I ordered a template kit, ordered and installed custom tailgate padding from SeaDek Marine. SeaDek Marine Products - Swim Platform Pads
Drove out on Cape Hatteras this weekend and it worked great!
Wow that looks great! So how do you go about getting this? Just buy the template, draw it all out, and send it back to them to make?
That's correct. Order a templating kit, then mark it out and send it back. If you're brave, just tell them you have a 99 LC and they'll send you whatever color/ pattern you want that matches mine. Not sure how the 98-06 tailgaits differ.
Damn. Need more information. Waaaaay more.
The tailgate is covered by a thin piece of luan with carpet stapled over it. I took the carpet off by pulling out said staples. Super easy. The whole assemply is held in with body clips that easily come apart. Once you've got the luan separate, measure with the included template materials from SeaDek.com. After that, and once you get the final padding back from SeaDek, it's a simple peel and stick appication. If you mess up, you can simply pull off and reapply. Now that I've got this done, I'm seriously considering doing the entire back of the truck vs. my existing weathertech mat.
