I've been eyeing up the ali-express drawer systems for a while as I've not had the ££ to throw at anything more Gucci.
The stars never aligned with finding one in the right format/price, so I decided to build my own.
I've been using 18mm hardwood plywood, which in hindsight might be a bit overkill as the current unfinished drawers are heavy to move.
I've still got to do lots more to finish them yet, I also had fitted a drop down extendable leg to the pull out 'cooking table', however my measurements were slightly out and it's too long to open because of the lower tailgate. I'll be testing whether I need it, as the runners I fitted are sturdy! If I do need the table leg, I'll have to figure out a quick mount option.
Once I've finished it I'll be carpeting it, along with side panels to give it a more fitted look.
I'm also undecided on how to secure it down, but it's a tight fit already and heavy. I've got some tie down lugs that I planned to secure to the sides (hidden by the side panels) of the unit and then strap them to the tie downs in the cargo area. I didn't want to be putting screws into any part of the floor with the rust issues we have here.
To be continued!
My son did something similar in his 80...same size plywood, 50–lb full extension slides (per side), etc. We designed in tie down oints on the sides, but empty the thing was so heavy we never used them.
Replaced Charcoal Canister with an assumed 301,000 miles on it with a used eBay unit from same month/year LX470 with 171K mile on it (claimed).
$200 hurt a lot less than $700 for Wells/WVE aftermarket of indiscriminate origin. (Although on Rock Auto they sure LOOK like OEM)
The brakes feels like factory on regular stop and go around town. I haven’t changed anything yet in the brake bias, most likely in the next few months in prep for our Montana and Colorado trip this summer. It’s shines on peculiar situations which I had two already (near animal strike in UT and freeway hard braking in SoCal) since putting them on, better brake torque is obvious. It feels like it’s back to stock weight like it had no 35s and all the additional mass.
Which brakes are those? Also, hit me up when youre in MT!
Plugs and Coils this weekend.
Went to check torque on the plugs at 62k after reading another post about blown plug. Found the coils on left bank were starting split at the seam. Coils are original 248k- truck ran fine despite coil housing beginning to fail.
Plugs were the standard Toyota - Denso SK20R11 with 62k miles- they looked fine and gaps were all 1.1 same as when they went in.
I had new plugs and coils on hand waiting for the next timing belt service but decided to install new the new plugs and replace all 8 coils. Went with NGK IFR 6T11 this time around to see how they behave compared to the Denso.
For sure. Ouray CO is definitive but we still haven’t finalized yet where in MT we’re going. The Big Brake Kit 6-piston front and 4-piston rear I have is the same BBK product I distribute here in North America and Canada.
Hey Trapper50 tell us why you decided to ditch the Wildpeak MT tires for KO2s?
Thanks!
Three reasons:
-A Rising Sun member was selling them - all 5, with about 70% tread remaining for $200 in Denver.
-They're slightly bigger - the 295/75r16 is 33.4" tall and 11.6" wide
-It's Winter (although you wouldn't know it so far) and I wanted AT's on instead of Muds.
The positive side effects of this move are that they are MUCH quieter on the road, smoother
and the vibration/drone I was experiencing at 51-54mph is gone.
I sold the 6 Wildpeaks I had for $300, so after giving a friend $100 for gas money to bring them
back down with him after a trip up to Denver, all I have spent on them is the money to have them
mounted and balanced.
The trade off is that they are 8.5 years old, but they were always garaged and had zero dry rot
or cracks in between the lugs of the tread or anywhere along the bead or sidewalls.
Three reasons:
What did you think of the Wildpeak mud terrains on the trail?
They aired down to 16psi well, with no adverse effect, did well in the sand, weren't the very best on slickrock but that's to be expected. Didn't ever have them in substantial mud. The outside shoulder lugs cupped pretty severely even after proper alignment.
To be continued!
I put loops on the rear sides and side front of mine and used ratchet straps to tie it down to the load loops already installed on the floor. It may not move in regular use, but I'd rather have it secured if we ever have a crash.
Noticed my brake fluid was getting low (down the MIN line) and figured it was time to change the pads. Good thing I did because I had just under 5mm of pad material left when a new set of pads have somewhere between 12-17mm of pad material (per google). I dont know why I psych myself up so much when I go to tackle a job. Removal of pads was pretty easy as I didnt not have a caliper clamp, I just used my good pry bar and pushed the pistons back using the old pads. When I took out the old pads I noticed that the "M" shaped wire was previously installed on the bottom instead of the top of the caliper, I imagine it probably doesnt make a difference but when I put in the new pads I placed that wire on top.
Took it for a spin did some bedding in procedure and I can check this off my list for a bit.
Quick 500 mile round trip was a success!
How's the clearance with that rack sticking out so far like that? I had a metal utility wagon some years back that I modified by welding a receiver tube on the bottom of the frame so I could tote the whole thing on the hitch (kinda like your rack setup, just with a cage around it, wheels removed)...
IIRC, my ground clearance at the back measured around 12" (I angled the receiver tube so that the rear was higher than the side attached to the hitch) and stuck out about two feet or so from the rear bumper and I found that it would scrape on even mild inclines...
