What did you work on tonight? (6 Viewers)
UNIMOG got a fresh coat of monstaliner thanks to help from Virgil and my son. Long day but I'm happy with it
It's coming along. Can't wait to see it driving.
I hope you and your passenger are relatively small people in stature. That cab was built for German gremlins.
I did see a stool in some of the photos.
I’ve been working on diagnosing a noise the 4Runner is making for awhile now @alia176 is familiar with the noise from driving it. I initially thought wheel bearings so I replaced them during the front suspension rebuild. But now that the 4Runner is on the ground and driving again it’s still making the same noise.
Last night I put grease in all the zerks on the driveshafts and tried to find play and I don’t feel any play that seems abnormal.
Here’s what I’ve got for symptoms so far, the noise is a light pssshhh like a dry bearing would make:
  • Only happens when rolling above 10mph.
  • Not rpm related only rolling speed
  • clutch position or gear or trans in neutral do not change the noise
  • Neutral on the tcase makes the noise much quieter but it’s still there
  • Noise is louder if you put your hand on the tcase shifter
I know the rear axle seals were done before I bought it, haven’t looked too close at the papers but I’d imagine the bearings were also replaced when that was done.
I’m thinking I’ll drain and fill the front diff and t case but now I’m stumped. I’ve read about the pinion bearings going bad but don’t know how I’d diagnose that.
I will bring it to the monthly breakfast on Saturday if anyone has any ideas
Output shaft bearing on transfer case?
Yep...had to delete the steps since I went with larger tires. New steps will be made at some point. Also, the roof is around 8.5 feet tall so we needed something to get up and spray the truck.
I'm a little taller than you but I don't think any human could work on that thing without a ladder.
Well found my noise
This is everything that came out of the transfer case.
Filled it put it in gear on jackstands and let it spin for awhile and emptied it.
@Dumpolina in the reflection (big thanks to him for the help) We also put mystery rear springs on his 4Runner to replace the LC80 fronts and it’s no longer stink bugging, he’s gotta give us an update on how it drives loaded down tomorrow.
If anyone has any tips for flushing this out Im all ears, just planning on a bunch of tcase fluid changes in short intervals with whatever fluid is cheap until it runs clearish and I’ll put redline or royal purple in it when stuff stops coming out.
or if anyone has a 3rd gen 4Runner tcase for a manual trans they’d sell I’ll be looking for a backup tcase to add to the parts hoard I’m starting
Well found my noiseView attachment 2844100
I would fill it with diesel fuel and take it for a short slow drive then dump it.
Tanner,
Glad you found the source of the noise but any idea what has come apart in your Tcase? Since you have a backup ride, have you thought about tearing into the Tcase and replacing what's needed? These cases are relatively easy to pull apart and work with. Toyota or Cruiseroutfitters should have all bearings and sprockets. Just a thought.
Tanner,
No idea on what’s damaged, the case has orange rtv instead of the Toyota black so possibly a bad reman case that got even worse because it got ran dry. Found one that came off a manual 4runner on Facebook and I guess as long as I find a j shift in the upull I can make that work too. Plan so far is to get a spare and possibly rebuild it on the side and do the swap later on
Definitely a possibility, tried to give the driveshafts a good shake while I was greasing everything but didnt feel anything I thought was bad. Maybe I need to lift the rear wheels off the ground and spin the ds by hand
@5speed addict an you drop the shaft and spin it freely by the flange? Or run it at idle in gear with no shaft?
Toyota FIPG is orange.
it’s sloppy, and the tail cone is way cleaner than the case… really looks like someone’s been inside it.
The grit is super fine, almost looks like aluminum.
I’d take @Mauser ’s recommendation and see how much life you can squeak outta this case while you get the spare one sorted out.
@5speed addict sorry to lead you astray, @pappy of course is correct that Toyota fipg is orangy-red. But what’s on your case to me looks like orange RTV… I’ve made the mistake of using it too much in the past to not recognize it 😬😬😬
Thanks @5speed addict fir the nudge to swap these springs. Left is the Fj80 that was on it, right are what we put in. @lurch these were in an OME box labeled OME860 X, they look like a factory Toyota coil but no markings as the plasticoat covering is flaking off.
