What Did You Do with Your 80 This Weekend? (78 Viewers)
Unpacked my slider frame mount kit from 4xInnovations. Might even start install if I'm not too hung over tomorrow.
So far... Oil change, re-attached my drivers side rear shock again.... Bought a 26" bike tube to fix my sunroof. And an Estes Nano Proto X. Damn cool.
Carpeted my drawers wih my 2 helpers..
Also installed new front rotors, I got the slotted version. Repacked the bearings and torqued the preload nut to 20-22ft lbs, much better!
After bedding in the brakes she stops much better, even better than when she had 33s on.
ewwww and not a tree in sight to attach your winch too!
Got stuck.
You know, I'm an hour north of the ND border, and we have minimum 3' of snow everywhere still, with a storm forecast for tonight, and you guys are damn near completely melted. Crazy.
084RUNNERLTD, first off the :princess: didn't look impressed with your skills and second, you could have waited for the water to dry and just drive out. Anything better then a Ford rescuing you :flipoff2:
Although on second thought, better it wasn't the Polaris that saved you :hillbilly:
We had one of the record lows for ND snow totals of the year...only around 12" or so. Well the rest of the country got hammered.
They tried....
Finished up my front shaft rebuild and got it re-installed. Much more gooder.
Found that using a 12ton press was much easier than trying to hammer them out, and that it really sucks if you push the top cap too far, as there is no going backwards. Then you have to grind the hell out of the cap so it can come out the inside.
Installed my new brackets from Frank. Flipped my rear drive shaft front to back at the suggestion of Bryan at ACC... vibes now gone. Reinstalled my Landtank front shaft
Do you mean that you turned the driveshaft around so the spiine section is now at the diff side? What is the theory behind this?
