What Did You Do with Your 80 This Weekend? (55 Viewers)
Scotchlocks suck.
Ok, with that preliminary stated... Friday, driving along and noticed the EGT gauge wasn't operating. Ok, something to do on the w/end.
We had done a fairly long road trip to drop off a bed from my younger son at a friend's warehouse near Sac, so quite a bit of fuel used. Anyhow, next morning son borrows the 80 then comes back saying that the fuel transfer wasn't happening when he pressed the button (main tank down to yellow light). Hmm, ok, check it, yep, no fuel transfer. Ok, fine, he takes the jeep instead (full tank).
So, look over my notes and notice that I had taken power from both the EGT gauge and the subtank transfer module from the same point. Hmm.... many many years ago.... hmm... scotchlock probably?? Open up the DS kickpanel and look for the wire splice - yep, POS scotchlock. Jiggle it and gauge works, fuel transfer works when button pressed.
Remove scotchlock and toss in bin, replace with a posi-tap! Should be good forever now.
Pays to document any wiring you add - you'll pat yourself on the back when years later you need to figure out a problem.
cheers,
george.
The 80 hit 120k km's/74.5k miles(purchased at 115k km) so did the first oil change since ownership. Replaced all interior, exterior bulbs including headlights with LED, with the exception of headlight fogs(factory equipped on my fzj81). Couldn't find H3C LED conversions that had a built in cooler/fan for some reason.
On the topic of factory fogs, does anyone know where to connect auxiliary fogs that are switched on using the bottom of the factory 3 position fog switch? Top position turns on headlight fogs, center is off, and from what I've read on here the bottom turns on auxiliary fogs usually mounted to bumper?
Sorry for the s***ty pic of faded switch...
  • Like
Reactions: RFB
Finally done! Total of 18 hrs start to finish. That’s probably twice as long as it should take but I don’t work the fastest. And was quite a bit rusty. And I painted stuff. Only damaged one seal and it probably would’ve been fine if I had left it but since I had some on hand I swapped it out.
She stops on a dime.
And filled the diff with the oil pump that @LandCruiserPhil recommnded a couple of years ago. Filled the front diff in about 3 minutes. I had forgotten I had it!
All new axle seals, bearings (saved the old Koyo bearings for spares for the next kit if they are needed), new rotors, new calipers, new pads, new brake fluid.
And shout out to Joey aka @NLXTACY for the reference guide and Kurt aka @cruiseroutfit.
But the biggest shout out to Onur aka @beno. Walked me through multiple steps I wasn’t confident in. Thanks bro!
View attachment 1750629 View attachment 1750630 View attachment 1750631
Well would ya look at that...
Looks like a ******* chirkus(circus to everyone not from Poland) show!
Looks nice and a great effort was made
...any superseded part numbers on the T-shirt?
Still a few years away from having the space to break knuckles. What a relief to get it done LS1FJ40. Congrats. Time honestly spent.
Hit the 85k mark on the way from seattle to Bend, OR.
New motor has now almost been broken in at 600 miles .
Averaged 14.7 with a roof box going 75 on cruise with the A/C on!
Also found some play in my knuckles 9to3 wise .time to retorque hub nuts in the parking lot. Guess the new bearings seated more!
From what I've read any play in the 9 to 3 direction is steering linkage related. 12 to 6 is for the hub bearings.
I did mine in my driveway. I looked like the Clampetts.
As far as parts number...I don’t worry about parts numbers. I call @beno ir @cruiseroutfit when I want parts. It’s their job to know what I need and what part number. I pay them for their expertise not just parts.
Road trip to Long Beach, WA (about 650 miles round trip). Met up with friends and watched the kids play while we drank beers. My buddy broke out the drone and grabbed some photos.
The only downer was hearing the left front tire start to make the "wump wump" noise on the way home, along with some unexpected brake screeches, indicating its time to finally tear into the knuckle rebuild wheel bearing replacement job. I nursed it home because I didn't have the tools with me to try and tighten it up, and nothing was open Sunday evening.
^ note to driver in pic - must keep thumbs OUT - or potentially lose thumbs...
Looks like a nice trip and no crowds!
cheers,
george.
It might be a difficult question to answer by anyone outside your geographical area. I can't recall anyone having factory installed fog lights and that switch.
It seems as if you also have a headlamp washer. In my limited experience with 80 in NA I have not seen anything like you have on your rig.
Rattlesnake bar! ;)
The OPOR sliders arrived in time for my CO trip. MetalTech was awesome with their communication, i can't say highly enough of these guys.
The sliders went it nicely no problems. Got plenty of clearance between pinch seam and the slider.
Delivered
Prepped
Based of POR-15, Painted/Coated with VHT
Installed
Kids happy to have a step again! What would i do differently? I should have probably ran a steel brush wheel since there were weld spatters that i didn't notice until later after the POR15 base (did it at night so no proper lighting), not really an issue since we're talking rock sliders here :)
Nailed down my L-Track in the cargo area finally. Decided to skip the wood base and mounted straight to the steel floor. Securely mounted the ARB fridge and Subwoofer. Installed ARB fridge power portal under Puma mount and wired everything up nice and tidy.
Installed a 3 outlet AC surge suppressor (1080 joule rating) with built in 4000 mAh USB portable battery pack to accommodate my ARB fridge and CTEK battery charger. Makes the battery much happier over the weekend. :D The battery removes very easily so I had to tie it in with some paracord. Need to come up with a better (nicer looking) solution to keep it in place while I'm bouncing around. No longer have to raid my work backpack for a USB battery on camping weekends!
https://www.amazon.com/gp/product/B00O5FLFNW/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
The CTEK charger gets pretty warm but does fantastic on the wire rack. Plenty of air flow. Just need to move all the rack pieces around to keep the blanket and jackets away from the warm stuff. :hmm:
Good to know. I torqued them per the tools method and was surprised I found play in both front wheels 3-9. I'll try to do some research. I felt the tie rods and couldn't feel play .
True, I know NA didn't get the headlight fogs. Thought I'd reach out to the hive mind as I know there's a handful of Oceania folks on here and some that have imported 80's from Japan into NA. I'm having a bumper fab'd up and bought some baja designs fogs for the bumper and would be nice to get to use the switch. Too bad you can't have both the bumper and headlight fogs on simultaneously with factory switch. I'll continue to look for the connector and post up when I do find it.
Pics of JDM headlight fogs and washer nozzle for fun... (uses H3C bulb and bulb itself is clear)
