Speaking of Bowfin Racks...
I got the solar panel nestled down below the crossbar level so I can still use the full rack when needed. Next up is L-track runners down the sides for tie-down po
I got the solar panel nestled down below the crossbar level so I can still use the full rack when needed. Next up is L-track runners down the sides for tie-down points.
Additionally - found out the rack runs through the auto carwash just fine. The operator looked at it for a bit, shrugged, and let it through. Worked out fine.
Most frustrating part change of my life! Such a simple procedure that's such a PITA.Not that big of a deal (typed with one hand since my wrist now faces the wrong way from doing this)
Have you replaced the VSV with the upper plenum still attached?Most frustrating part change of my life! Such a simple procedure that's such a PITA.
No but I wouldn't attempt to, either. I've replaced the hoses on it but if I had to replace the actual VSV I'd save myself the tedious headache and just remove the plenum. And if I removed the plenum I'd replace that damn fuel filter again and relocate the VSV for future endeavors!Have you replaced the VSV with the upper plenum still attached?
What paint are you using? It looks great!
I gotta do the same thing to my white cruiser. Turns out a couple does have been repainted with what looks like no clear coat.
What are you doing with your paint? Can you describe the process and purpose?
