@Nay Yes, they are adjustable, but your'e probably too early in the pulling process to start adjusting the hood hinges. Use the hood as a guide to get the core support back in place first. Also, remember to measure diagonally across the the engine bay from the rear fender bolt of one side to the front bolt of the other side. That will tell you how close you are to being square. Getting is square should be the first goal
Agreed - I’ll probably need to take you up on the offer for your expertise. Made some good progress today, but where the core seems off a bit is all the same movement with the entire fender assembly rolled outwards and slightly down. It’s not much, and it doesn’t need to be perfect, but it seems to need pull from multiple points simultaneously.
Body mounts over the frame look good after the frame alignment, but definitely still more to do at the core alignment level. It is fun working on it, though - has already become a “will succeed” project.
Additional parts bin pulling objects have been deployed.
Lots of banging involved.
