I did a coolant flush and belt replacement. Slowly knocking out things as I get ready to go down the turbo rabbit hole.
Yes I know that but i thought the Birf would be threaded Metric? Or am I incorrect. Better if it's NPT.NPT is National Pipe Thread
Yes they are air chuck fittings. As far as working out, so far they have been awesome although I was a little concerned that they might wear out or fall off. Also I didn't like the way the small amount of play in the fittings allowed the flaps to move up and down a bunch but I was able to address these two potential issues with my design. I welded a male fitting to a piece of plate that simply bolts to the bumper via one of the existing bolts on the 4x4 labs bumper. On the actual steel part of the mudflap I welded another mail fitting with the threads sticking out just far enough to screw the quick release onto. The bolt on the bumper aligned perfectly with one of the cool guy go fast holes on the bottom of the bumper so I was able to glue a small piece of the rubber mudflap leftover from trimming to the top of the steel part of the mudflap. I simply used a nice large zip tie to secure the mudflap to the bumper for extra security just in case the quick release somehow failed. Securing the top of the mudflap against the bumper along with the little piece of rubber that I added also took the wiggle and any rattles out of the picture. I went budget and used harbor freight fittings so if the quick disconnect part ever fails it will be a simple cheap replacement. For the rubber I went to the local Six States and bought a set of small mudflaps that required some very light trimming to get the exact size that I wanted for my rig. Here are some more pictures to help explain.Are those air chuck fittings used as a quick disconnect for the flap? How are they working out? Solid enough? I gotta do something similar soon
I believe the birf is actually BSPT which is British straight pipe thread. A standard NPT fitting doesn't fit quite right.Yes I know that but i thought the Birf would be threaded Metric? Or am I incorrect. Better if it's NPT.
I carry my chainsaw with extra pre-mixed gas and steel-toed boots just for occasions like this. Nothing more aggravating that having to turn around and go back the way you came. On some trails turning around isn't a great option.
View attachment 2286799View attachment 2286800
That is quite alright if you borrow my idea, this forum is the best and I am happy to contribute anyway I can.Thanks for that, well done. I might be stealing your idea, or some variation of it. No royalties though 'cause I'm a piece of s***.
Check with Wit's End @NLXTACY as he has made a fitting to fir as well.
I indexed a 3/8-18NPT Tap with the original BSPT plug that came out of the steering knuckle and the first four threads (all that was engaged with the original plug/knuckle) line up almost perfectly. Using brass as I did (being a soft metal) will in no way damage the knuckle and in fact create a tighter seal.at 1/8 NPT and BSPT are close enough to be interchangeable (27 vs 28 threads per inch). Goes to s*** after that. And yes, Toyota uses BSPT for sure.
I know this because I lost my original plug for a while when I did my front axle rebuild. So I grabbed a 3/8 NPT plug and screwed it in. It was a steel plug and I had to run it for about two weeks until I found the original one in a box in the garage.I indexed a 3/8-18NPT Tap with the original BSPT plug that came out of the steering knuckle and the first four threads (all that was engaged with the original plug/knuckle) line up almost perfectly. Using brass as I did (being a soft metal) will in no way damage the knuckle and in fact create a tighter seal.
It did get tighter faster but I was able to still engage the same four threads of depth without binding. (YMMV as not all pipe fittings are created equal)
This is a non-issue in this application as all the plug does is seal the knuckle inspection hole.. it is not a load bearing part, all it has to do is stay tight and not fall out under vibration.
But... if you want to be a purist with no real world trail experience.. dig on!
Here is the correct fitting to build this Zerk plug if you are so inclined.
3/8-19 BSPT Plug Steel Hydraulic Adapter
This is basically my life right now tooBusy past week but glad to be done. Did a complete rebuild of cooling system. Was in really bad shape. Bypassed rear heater. Bypassed PHH. Not sure how old the CSF radiator is but the core was rotting. Fixed all the oil leaks on the front of the motor. Motor mounts gave out and went through three class 8 bolts to get the crank bolt off. Used an OTC pulley holder and 40" 3/4 breaker bar. Someone put thread locker on the crank bolt in the past. I'm glad I bought a new balancer because I discovered the rubber ring was delaminating and making contact with the motor. Vibrations gone now too so that's a crisis averted. Someone also torqued the lower oil pump cover screws down hard and I broke a #3 bit. Had to drill that screw out.
Here's some photos of the worst stuff I pulled out.
You can see the rot in the lower left and upper right.
Luckily I could only find build up around the radiator hose connections on the lower side.
View attachment 2286994\
Balancer.
Where the balancer was making contact with the motor. You can see the polished arc across the oil pump cover and timing cover.
Glad the mounts gave up in the driveway and not a trail. Needed replacing anyway. I'm never doing it without a engine hoist again though.
