cruiserinsanity
Replaced the rattle canned vents on the fenders with stock chrome.
where did you order these? Pretty much only outside body piece I hvnt found OEM replacement forReplaced the rattle canned vents on the fenders with stock chrome. View attachment 2921714View attachment 2921715
I didn’t order them. Parts stash.where did you order these? Pretty much only outside body piece I hvnt found OEM replacement for
ClassicCruisersLLC probably has some.where did you order these? Pretty much only outside body piece I hvnt found OEM replacement for
sold out lolClassicCruisersLLC probably has some.
@cruiserinsanity was telling me that the 3FE has been difficult to start lately and the condition has been worsening. We were using the 60 to winch stuff off a trailer today and after shutting off the engine restarting it took much more time than normal. We talked about the symptoms and that this was a fuel related issue. I knew that I had a spare fuel pressure regulator in the parts pile, well not just one but twoNOS that were both purchased in 2013. We swapped out the old one and that cured the issue.
View attachment 2919889View attachment 2919892
I might have a pair of these… I’ll check..where did you order these? Pretty much only outside body piece I hvnt found OEM replacement for
Parts box is in the storage unit. I have to run up there today for wood clamps anyhow, I’ll grab them for you. 99.99% I kept them. They came off my ‘84 parts truck way back when I first got sick with land cruiser derangement.I might have a pair of these… I’ll check..
@NeverGiveUpYota this could be your issue. I wouldn't use Bars leak in any vehicle. Thanks @Ernboto .I got my rear heater working finally!
A few weeks ago I found the lines completely clogged by the PO’s liberal use of Bar’s leak. It took a pressure washer, a fish tape and a coat hanger wire chucked up to my drill to clear it.
While I was at it, I installed a new thermostat housing, new thermostat and o-ring “which was previously missing.
When I put it back together there was no heat at the rear, WTF?
So this weekend I replaced the lower thermostat housing (finally found a good used one) and took another look at the heater plumbing. I figured I should start at the next lowest point since I found so much sludge in the hoses. So I started at the “Y” and sure enough I found the connector completely blocked with coppery sludge. I got a very thing back together and bingo! We have heat ladies and germs!
Never assume the problems you find are the only ones that exist.
Appreciate the thought + effort...ill most likely jus reuse mine if I cant find new.Parts box is in the storage unit. I have to run up there today for wood clamps anyhow, I’ll grab them for you. 99.99% I kept them. They came off my ‘84 parts truck way back when I first got sick with land cruiser derangement.
Could be. I haven’t pulled those rear heater hoses even tho they really do need to get replaced.@NeverGiveUpYota this could be your issue. I wouldn't use Bars leak in any vehicle. Thanks @Ernboto .
They’re broken anyway.Appreciate the thought + effort...ill most likely jus reuse mine if I cant find new.
