What did you do on your 70 series today? (12 Viewers)
Smash and grab last month. @ofer bruhis to the rescue! I asked where to order new glass, and he said he had one 7 miles away, but he didn't know which side, and told me to come by the next day after work. Fortunately he had the correct side, and I installed it the following day. Less than 3 days start to finish, and it didn't rain. This greatly reduced the sting of losing $700 of snap-on wrenches my uncle gave me 30 years ago.
Thanks again Ofer, I owe you big.
Aaron, any time mate. Was not aware of this post. I have soooo much stuff to write but posting it on my build. 😂
In prep for workking on my HZJ73 this spring and summer, I organized my two recent parts deliveries. A small one from Toyota and a BIG one from 4 Wheel Auto in Edmonton (thanks Dan).
Steering refresh:
Knuckle repair kit with wheel bearings and seals​
Relay and Tie Rod Ends​
Stabilizer Bar Bushings and hardware​
Steering Damper​
Engine Maintenance - Filters:
cont...
Brakes - Front and Rear Rotors and Pads, Parking Brake shoes and hardware, and Brake Lines. I probably should have ordered new hard lines, so they will be next
Diff and fluids:
Front and Rear Pinion seals and nuts​
Drain Plugs (low profile 1cm hex) and Washers for steel and aluminum​
New light bulbs. I went old school 24v incandecent. I'll go LED on the next refresh in 2053!
cont ...
killer,
my new toyota rocker steel keeps looking at me from the corner of the shop!
I was being a little silly, shoulda used a smiley, but, yeah man, they have all kinds of stuff for recievers, some of them are kinda crazy actually.
I've seen lots of stuff for female receiver hitch sockets. There is also the smaller 1"? receiver that is used for lighter duty vehicles. If you're bumper had multiple of these female sockets across it you could have a variety of ways to mount equipment carriers when needed. Not just the 1 center receiver hitch mount...................Are you familiar with the Molle system for military web kit. Lets you change/mix/ mount different kit for various mission needs.......similar idea but for vehicle.............................My next bumpers on my next project build will have something like this.
Installed a dual battery today. I went for a Bluetti EB55, with 450Wh consumable power out if LiFePO4s and 700W inverter. Got a good deal on it, which makes it cheaper than individual components.
It has all connectors on the front, a flat top and nicely fits the Eurobox-layout, my interior storage is based on.
It charges on 12V and 24V at 8A (regardless of actual voltage), so in my 24V BJ73 it charges at almost 200W. From empty to full in just an average wheeling day.
At 8A it would flatten my starter battery in no time, so I run the charge line trough a battery guard and a relais switched by the ignition.
The box supports simultaneous charging and discharging. The 12V outlet connects via XT60 connectors to my vehicle's power distribution (fusebox, USB, DC sockets, lights and fridge). All my devices are dual 12V/24V. When I take the power box out of the vehicle, I can connect the XT60 24V charging line to the distribution inlet, to power my devices from the starting battery.
Cheers Ralf
Hey Ralf, just curious... I setup a solar/battery system, but just with a regular deep cycle battery on my trailer I take on my yearly 2 week expeditions that seems to work pretty well.
Are you thinking of adding any solar backup charging for when your not wheeling? There are some pretty powerful panels out now that I wish were available when I installed mine. I think the most powerful I have seen available now (haven't checked in a while) are around 350watts from a single panel. On a shady day, even at 50% efficiency it would still be doing a pretty decent output.
Steering refresh:
Steering Damper​
cont...
Nice, yeah Dan is good people for us Canucks, he knows his s4!T
Hi
Yes, I was thinking to do so, but decided different:
The 450Wh are actually overkill for my normal power needs. I was thinking of a smaller device + a solar panel at first. I don't want panels permanently on the FRP top (too much hassle drilling into the roof and routing cables) , so a folding unit would have been my choice. But those folding panels are quite expensive, still. In my normal mode of utilizing the truck, I drive most of the day, and when I setup camp and could setup the panel, the sun is mostly down. I rarely stay in a place for more than 2 days. And if so, it's a usually campground with power supply. (This is Germany and The Netherlands: Wild camping prohibited).
So, for now, the budget went into more capacity, to cover >3 days with no recharge at all. Fun fact: The EB55 is only about 1inch wider than the smaller EB3A with just half the capacity.
Good thing: The EB55 is ready to take up to 200W panels plug&play. So l can upgrade as needed. Experience will show.
Cheers Ralf
Hey all, just installed all front tie rod ends and tightened up the play in my steering wheel at the steering box. I'm trying to find a shop in near bluffton south Carolina to do my alignment, I called the recommended Toyota techs in the shop thread but they aren't able to do it, but I have been calling shop to shop with no luck any help would be appreciated.
Hey all, just installed all front tie rod ends and tightened up the play in my steering wheel at the steering box. I'm trying to find a shop in near bluffton south Carolina to do my alignment, I called the recommended Toyota techs in the shop thread but they aren't able to do it, but I have been calling shop to shop with no luck any help would be appreciated.View attachment 3290646View attachment 3290647 View attachment 3290648
I would suggest posting your request in the Low Country (SC) chapter page. You are also fairly close to Savannah, but the Low Country membership are more active here on Mud so they might be faster with suggestions (follow-up).
Firestone offers a lifetime alignment. They did mine (here in the Seattle area of course, so quality might vary) for my 40 and 62 so they should be able to do a 70-series. No issues with either of them, and if there are they will realign them as many times as you'd like for free if you buy the lifetime version. I'd check with LDowney's recommendation and talk with the locals, but if you cannot find anything else its an option.
In the meantime, clamp a straight-edge (2x4) to the front tires and use a tape-measure to give yourself an 1/8" toe-in.
