It’s most definitely coming from the drivers side front. If it was in the back, it wouldn’t stress me out.
I figured it out:
Looks like after a few years my preload backed off on my drivers side spindle. 20min later, back to normal.
I assume you refer to the front wheel bearing adjustment? If so how did it back off?
Mine had a surprising amount of metal in the filter through all the break-in oil changes. Last oil change it was much cleaner. Still no sign of smoke or issues so I’m guessing it’s somewhat normal. I’ll let you know in 30,000mi
Did you build yours or did you buy a short/long block?
Rather you than me!!!!With the nice weather this weekend I got some more painting in before winter.
If it were mine I'd bolt it back up. What grade and size of bolt were used before?Need to get on rebuilding (cleaning the mud out) of my lockers, or so says Toyota. I wish I felt better about them in terms of them being truthful or helpful. I'd feel better hearing it from the tech directly.
Also, I'm down a spare now. I had been losing a bolt or two from the LF rock ring, ended up being 7 bolts now. Realized they weren't backing out, but instead they were snapping off. The ring is now bent and deformed and the wheel has 7 snapped off bolts to get out somehow. Best guess is that I hit something hard enough to shear the first bolt head or blew the bead and then the pressure just kept snapping them off over time. As soon as I removed the first ring bolt air came rushing out and the tire fully deflated. Once the ring was off, the tire was off the bead as well.
TLDR: Tire is off the bead and rim needs to be repaired.
Snapped off ring bolts
Tire after the ring was removed
Pretty sure this will need to be replaced unless Brian or Andy think it can be pressed flat again?
Yet another costly lesson being learned.
Top pic left most bolt hole. Is that a crack?Need to get on rebuilding (cleaning the mud out) of my lockers, or so says Toyota. I wish I felt better about them in terms of them being truthful or helpful. I'd feel better hearing it from the tech directly.
The impact had to work to get them loose.
