Thanks for the info and pics everyone.
I'm installing my new Thermo Top C into my 1HD-T powered LX450 (LHD), it's going to be mounted off the right side shock tower, kind of beside the Cruise control motor. I have a blue sea distribution panel right there so power sourcing will be easy. I have zero room on the left hand side due to the ABS module, LHD brake booster/cyl, steering shaft, etc...
Previously I had installed a percolating style 110v block heater, it sourced coolant from the block drain, nice and low... just under the IP. So my plan is to re-use that coolant line as the source for the Webasto... run the input line up and across the engine kind of like how
@Malahki did (except his is the output line, of course).... to the Webasto, then from the Webasto directly into a Y connected to the heater core return line back into the engine. This, like
@Malahki 's setup, would bypass having to run it through the heater core first before it reached the engine.
The only downside I guess is that the coolant line has to go up and cross the top of the engine near the firewall. Would be better to keep it less in the way, but... not sure how to accomplish that. Perhaps a custom 5/8 hardline as it crosses the engine? Maybe as simple as zip ties... LOL damn rednecks.
Diesel line I plan on tee'ing the 12mm fuel line between the firewall hardline and fuel filter. 12mm - 5mm - 12mm (I still have yet to source such a tee!), then running the small 5mm Webasto provided hard plastic line along the firewall over to the Webasto. Somewhere in there I'll put the pump as well, probably as low as I can, perhaps near the tee. I have a RG-58 cable from my VHF antenna running along the little OEM clips there, hoping to use those for the little hardline instead.
@Malahki , any regrets plumbing yours this way?
