Warn M12000 Rebuild (10 Viewers)
San Jose California
In this thread I'll be documenting the take down and rebuild of a Warn M12000.
Before I begin, I'd like to explain my reasoning for rebuilding a used Warn M12000 vs. simply buying a new Warn, or another much less expensive overseas built brand.
The primary reason why I focused my efforts on a used winch was my desire to rebuild it to gain familiarity with what will become an important part of my vehicle. It also looked like fun. :hhmm: If I am looking for a used winch, price could be much less of a factor (if I am a smart shopper). Plus there were a few upgrades I wanted to do as part of the rebuild, and that is more cost effective on a used winch vs. buying new and replacing brand new parts.
So now I know I want a used winch, but what brand and size? After doing a ton of research, I couldn't really find anything technical that would sway me one way or another to buy a particular brand. However, one major advantage to Warn is their U.S. based customer service and availability of replacement parts. The only consistent knock to the overseas brands seem to be their customer support. This difference made Warn the platform of choice for my project. Picking a size was the easy part. For my heavy 80 series Land Cruiser (and getting heavier), a 12K winch seemed like the perfect fit. So, off I was to find the ideal Warn M12000.
I had been looking for a long time (several months) to find a used Warn M12000 local to me. Most of the ones I found were slightly used and getting close to the asking price of a new winch , or relatively inexpensive and beat up really bad. One finally came up on Craigslist. Asking price was $450. I confirmed that the winch spooled out and in under power. It also free spooled. I bought it the same day it went up for sale.
I called Warn customer service to identify the year of manufacture from the serial number and date code, and they told me the winch was made in 1993...about 20 years old. If you click on the text under the picture, you can get a larger view and will be able to see the surface wear and some corrosion. As part of the rebuild, all parts, which are reused, will be cleaned and all external parts will be painted.
I'll document the project in multiple posts and probably ask lots of questions along the way. ;)
Winch Take-Down - Gears and Housing
Opening the control box, I found dirty solonoids that need cleaning, but the wires are in good shape.
Dirty Solonoids
Opening up the housing for the planetary gears, things look okay, but need to dig in further to get an idea of condition
top of planetary gears
Break down of planetary gears. A lot of caked on dirty grease. A little rust is present but not on the actual gears
planetary gears
Teeth in the housing look good
Housing
I believe older model warn winches have these small ball bearings. I've cleaned these and noticed that some are in great shape, while others have some rust/pitting. Probably will replace all of these with new
ball bearings
Winch Take-Down - Drum and Brake
I wanted to completely clean up the winch, and doing so meant doing a deep clean of the drum. To do this effectively (and easily) I went ahead and removed the brake (even though Warn tells you not to do this unless replacing). With the winch being 20 years old, I thought it wise to completely dismantle. If I can't rebuild the brake components I will have to buy a new pre-assembled piece.
rust on drum
C-clip holding brake in drum
brake components
Winch Take-Down - Electric Motor
I will be the first to admit I do not know much about electric motors. Here are some pics from the housing and motor itself. Brushes look almost new. However it looks like maybe the motor got hot. Hard to say, as much of the discoloration is actually varnish that was sprayed on during the manufacturing process. I know this because I accidentally took a bit of the varnish off when cleaning the copper. I need to fix that. :doh:
motor housing with old gasket
motor housing
motor and housing
motor close up
inside of motor housing
ball bearings
Have you counted the number of ball bearings in there? The Warn parts list says there should be 85. I called Warn and they said there should be 85 (probably just read the parts list). Mine had 88 when I took it apart. When I put it back together I only put 85 back, which is still bothering me a little.
I counted 85 in mine.
PM me when you're ready to put back your brake assembly. I did a similar thread on here with my used M12000. When I called Warn I ended up talking to a guy who told me how to clock the brake spring properly. Probably not 100% but close enough to not pay for a replacement assembly.
I did the same thing to my M12000, it was a 2006 model year but had lived on a Hydro truck for all its life. Works great now and pulls like crazy, I had no issues re using my old brake.
Thanks iptman and wheelingnoob. Good to hear that rebuilding the brake is doable.
My parts are at the machine shop getting cleaned up. Once I get the parts back, I need to make a decision on either using a spray paint or do a powder coat.
Looking at the original powder coat, I am not impressed how it held up (on mine or others that have been exposed to the elements). I'm thinking that using a good high temp spray paint might be easier to touch up/fix. It certainly would be cheaper.
Thoughts?
Thoughts?
I painted mine, when I do it again I will powder coat it. The paint was done right and its just not as good as powder coat.
Cleaned M12000 Parts
Got my parts back from the machine shop. Exterior parts are ready for Powder Coat. I will do the drum too. I am planning to use synthetic rope. I think the powder coat on the drum will hold up better than if I used steel cable.
Parts look purdy! :p
Planetary Gears
Planetary Gears
I did notice some pitting due to the rust build up and age of the winch. However, I am sure it will be just fine. I sanded the pitted areas to smooth it out a bit.
pitting from rusting steel ball bearings
pitting on gear teeth
Replacement Parts
Getting ready to order replacement parts for my Winch. Besides the stickers, what are the recommended replacement parts for a standard rebuild?
There are some plastic bushings, snap rings, steel ball bearings and a few gaskets in my M12000.
  • All gaskets in the winch are a no brainer...they need replacing.
  • I'd like to reuse the snap rings...I was gentle taking these off. These aren't bent, so I should be able to reuse, correct?
  • This would seem like a good time to replace the plastic bushings. But is that necessary?
  • Some of the ball bearings are rusted. I figure I will replace all of these. Bearings from Warn are pricey, so I'll probably order from eBay. Does anyone know what specific type of ball bearings these are i.e. what hardness, stainless steel vs. chrome, etc.?
miscellaneous parts
New Grease
Got my winch grease in the mail this past week. Warn recommends a moly fortified NLGI #1 grease. The #1 moly grease is spec'd for stability at high heat and heavy shock loads, and is used in low viscosity applications, such as enclosed gear drives operating at low speeds. The #1 also has better low temp pumpability.
I couldn't find any NLGI#1 Moly Grease at my local parts stores (only NLGI#2), so I went ahead and ordered the specific brand that Warn recommends...AeroShell 33MS (replaces AeroShell 17). Kinda pricey, but not much more than the synthetic NLGI#2 grease when ordered online.
AeroShell 33MS
A Warn tech told me to only use enough grease to fill in the teeth of the gears. But then again mine wasn't the one with all the bearings.
Excellent thread! - I have a mystery M12K I bought used & lived in Wisconsin its' life - so I need to contact Warn to identify as the serial number is corroded to illegibility & all the paint was crap that I sprayed to give a few years easy life in WA - wet, but salt free.
I plant to tear it down, powdercoat the externals, and do a smooth down job & get the spool powdercoated in anticipation of synth rope as my steel cable is worn & clapped out.
Would a teflon content powdercoat on the spool be beneficial?
Can synth rope stay wet/damp all the time & it not being an issue? I ran cable this long as we have great grease to keep the core life extended.
Got a quote from a local powder coat company. I had asked them for a durable powder coat option and they mentioned that a hammertone or vain finish would be the most durable. They pointed me here:
http://www.cardinalpaint.com/products/productcat.php?pcid=2&cctid=12
I am not a big fan of how these colors look. The original powder coat finish was an Argent Gray. The newer models look to be coming in black.
The shop must do a lot of black powder coat, since the minimum price for anything other than gloss or semi-gloss black is $125. However, I can get a black powder coat on the winch parts for $75.
Unless someone has a reason not to use a black powder coat, that's the way I'm headed!
I read here that the rope needs to "bite" into the drum, or it will slip when spooling and you will have trouble getting a good wrap.
https://forum.ih8mud.com/showpost.php?p=1182693&postcount=4
This synthetic rope was first used in the marine industry, so I believe it can take being wet, although it will promote mold and mildew growth, and promote rust on the drum.
Water will not hurt the synthetic rope. But what sucks is when it freezes into one big block on the drum in the winter. I've had better luck with wire once it gets cold, and I think I'm going back to that for half the year.
No reason not to use black PC. And yes most PC shops spray black every day so they can group batches from multiple customers together. There are min purchase orders of powder in any color and thus the min work order for something other than black. My local PC shop has a $90 min but prefers more than that.
I probably used twice the recommended amount of grease that Warn recommended. They say to use just enough to fill the gear teeth. That seemed to invite more corrosion (than it already had) so I covered everything with a light coating. Its been 1.5 years so maybe I'll open it back up and inspect. But it works just fine with no signs of trouble.
