Build Warhorse-LS3 C&C & more
Just when I thought it was safe to walk past the blast cabinet and paint booth. Heat Shields and brake parts
I make the Power Steering pressure line in house. Auto zone can't seem to find the hose for an 87 Land Cruiser with an LS3. The line can be repaired in the field, re using ends and replacing hose. An Extra length of hose is in the center console. Odds are the owner will never need it.
The hose is high pressure line as are the AN fittings. This part threads on counter clockwise.
See the end of the hose inside the fitting, and the threads for the next piece.
This piece is threaded clockwise. Available in 90, 45 and straight.
Frame offs are never ending with little parts and peices that need attention or paint or both looks awesome when done but man when you take a whole vehicle apart and put it back together its a chore!!
Amen!
Edit: My neighbor stops by the shop every so often and he often marvels at the truck(s) blown apart in the shop. "I don't know how you keep track of it all"
Truth of the matter is it's like any other job, I write a lot down, I take photos all the time, I keep running punch and task lists. EVERYTHING gets labeled or bagged and tagged. You are indeed correct, it can be a chore. Dang pesky job thing :)
Stan's Cross Fit Garage
Been knocking down the punch list with what seems like a never ending list of tasks.
Twin sticks are in, waiting for a custom boot.
Making brake lines. I replaced every hard line on the truck, none were available in stock.
Do you prefer push lock vs AN? What’s the difference? TIA!
I can only assume that you are speaking of OEM style push lock fittings, I do not use them and replace them with AN style fittings in areas like the fuel system and cooler line fittings at the trans.
There are also "push lock" fittings within the AN fittings family. These are barbed fittings that insert into a special hose made to accept the fittings. A typical hose of the same size will not work. Over 10-15 years of use I have had only one come apart, on a trans cooler line. I now use Gates heat shrink hose clamps on them as well, belt and suspenders kind of thing.
AN style fittings also use a two part clamping style attachment system. This is used generally on higher pressure applications. An extreme example is on the power steering pressure line. This application uses high pressure steel fittings over the usual aluminum.
Both types of fittings can be seen in the photo
