Vendor - Trail Tailor (1 Viewer)
Here is my finished product now that I got the surface rust all cleaned up off of the frame. Oh and I cut the stock loops off so they wouldn’t be in the way. Had the tow hooks powder coated orange because it was free. :p My powder coat guy just threw them in with another batch of stuff.
Yes definitely a good time to do it! But not hard even if not replacing the radiator. I had to do it twice to make the install notes for TT and then again after I got them powder coated. Ratchet extensions are your friend and having two 19mm open wrenches is a big help as well as a magnetic tool.
You just need to loosen the bolts on the radiator to be able to swing the bottom back so you can insert the bolt. I used extensions through the bumper grill vents to get to the lower radiator bolts.
And two 19mm open box wrenches are helpful to tighten up the top bolts.
