- Joined
- Mar 28, 2003
- Threads
- 36
- Messages
- 1,189
- Thread starter
- #141
I've already greatly upgraded the main + cable from the alt to the fusable link as a result of my electrical failure at CM09 this spring. However the fusable links have really prevented me from doing this mod. Mr. T had to choose the size they did for a reason. But, I have not had the time to try to determine that reason. Was it to limit the OEM alt's output or protect other parts of the electrical system? If anyone kows please chime in. I hate chasing electircal gremlins so I'm reluctant to make mods to the OEM system without doing my homework first.
The fusible links and fuses are sized to protect the wires and components in that circuit. There also are unprotected wires on a vehicle. For example the wire from the battery positive to the starter has no fuse so there can always be problems. Fusible links are now mostly outdated and have been replaced with mega fuses. The 2003-2007 Toyota Sequoias where many of the upgrade alternators are coming from use a 140 amp fuse on the alternator circuit. See 2 in picture. In this upgrade it has been recommended that the charging wire from the alternator be increased in size and the fusible link replaced with a mega fuse. This is basically duplicating the Toyota Sequoia alternator “B” terminal to battery positive charging wire. .02 worth.
Bill
