This is what I get for procrastinating. I gather these brackets are long long with no plans on returning?
Anybody know if the pulley can be ordered new? I'd like to get a spare alternator and fit the correct pulley to it.
Dammit...
Sorry, I just need to vent a little.
I have problems with my "new" alternator. I am trying to get the pulley off the Alt I just bought off Ebay. While holding the pulley with a pipe wrench I can get the nut to turn but the pulley is spinning on the shaft while the Alt turns. The nut is not loosening. Is there any safe way to stop the Alt from spinning so I can remove the nut?
Edit: I couldn't see a way to get that nut off so I am trying to take the Alternator apart in order to find something to grab onto to keep the shaft from spinning. But I cannot get any further than the attached photo. Any place I pry is causing plastic to flex. I can't see how the rest of it comes apart.
Unfortunately so.
Well I'll just let myself back out of this thread then
Just finished rereading this thread as I'm thinking of tackling this project soon (got a bracket a while ago, just now getting around to it). I'm wondering if anyone has found a smaller-than-stock pulley to increase idle output and make the stock belts fit easier. If so, please post up! CDan- any recommendations on other Toyota pulleys that might fit the bill?
I got a bracket a long time ago and have yet to do the mod, however has anyone had any issues to date with their fusable links and the higher output on the upgraded alt? It seems to me that if you had a high enough current draw from something connected directly to the battery like a winch you could create a situation where more power than was origninally designed to flow through the links could cause them to pop. But I don't know at what level the fusable links are supposed to fail?
