I've done a lot of reading and searching on undercoating.
There are many opinions about what to use and what not to use. My question is, for an underbody that is stripped down to bare metal (with no rust), is there any benefit to using POR-15 instead of epoxy primer?
Either way, I plan to spray raptor liner on top to provide sound-deadening and extra protection against chips from rocks/etc.
From what I understand, POR 15 involves quite a lot of prep work and its only real benefit is its ability to adhere to and "convert" light surface rust. I've also read that if you're doing a bedliner-like material over the top of POR 15, you need to do so while the POR is still tacky, or else you'll need to spend a bunch time scuffing up the surface... in which case, I'd be nervous that I'd miss spots. Logistically, I can see having to spray bedliner while the POR is still tacky being pretty tough to do without the help of a few friends.
I think the fact pattern supports the use of epoxy primer, but is there some other benefit of POR 15 that I'm not aware of?
Thanks!!
Peter
Thanks!!
Peter
