Ultimate OEM 4X SERIES PARTS IN STOCK (2 Viewers)
Glow Plug Current Sensor for Super Glow 2H diesels. 28631-68020, courtesy of Amayama.
where would be a good start to find the Air conditioner compressor mount and engine mount to suit a RHD 2F FJ40 ?
Thanks in advance.
Thanks in advance.
Is a different part number listed for the rhd bracket than the left? I ask because I have an NOS bracket which is much more compact than the FJ60 cradle. I assume it’s an FJ40 bracket.
Of course. They’re different to LHD.
This does not follow. The transfer case output is still offset to the right side, and the engine is still offset to the left. The mounts should be the same.
This is incorporated with engine and power steering bracket in RHD models. Is LHD the same?
Incorporated into the lower mount on the right hand side.
Rubber plugs for the slots on the drum brake backing plates. Just checked this morning, still available.
There are different styles, I think to differentiate between the brake spoon adjusting hole and the opposite end "dummy" hole.
The plug for the adjuster hole is nice, because it has a recess to easily pry out with the brake spoon.
Does anyone know if the black plastic rivets that hold the black wiper access covers on the inside of the windshield frame are still available? It’s an ‘82 40. If so, what’s the current PN? thanks
@billmc
Are these access covers also serving as defroster nozzle guides?
These two pieces, each takes 4 plastic rivets. Can you believe there was a mouse nest it there! lol
You can still order these. You need 8, but I ordered a couple extra to have on hand.
90467-07003
Clip(For Defroster Guide)
[08.1980 - 10.1984] BJ42,FJ40
90467-07003
Thanks, That’s great! I’ll order 16 just in case I need to pull them off again.
