Malleus
Far west of Siegen
Here's the bottom of the head, in the machine shop.
What's the external Torx (if that's what it is) size for the tool to extract/install the studs? I tried using two nuts, without success (not the first time that's happened, either).Imo replace the exhaust studs and nuts, including the ones in the manifolds that connect to the downpipe.
For the dip, no idea. Could soak the whole thing in acetone for a few days, or try burning it all out like on YouTube.
On an unrelated note, what type/brand of flame arrestors are you using on your acetylene torch? I installed a set from hobo frate and now I can't get enough flow to produce a decent flame. My setup didn't have them when I bought it.Idk, I have a set of them and just pick the one that fits.
If the two nut trick didn't work, bind the nuts together tighter. If that still doesn't work, the etorx socket isn't going to work either imo.
Heat and penetrating oil.
It should be an E10 socketWhat's the external Torx (if that's what it is) size for the tool to extract/install the studs? I tried using two nuts, without success (not the first time that's happened, either).
It's a new tip. It works fine without the flashback inserts, just doesn't want to flow with them.have you tried cleaning the tip?
This can make a hell of a difference on the ease of setting up a cutting flame.
