- Thread starter
- #21
How? He's already given you all of his moneyIt helps for sure. go tell @sogncab to spend some more money lol. He's close to you.
It is so worth it to find a local fabrication shop or even SendCutSend for sheetmetal partsA lack of a plasma table or press brake (yet) that can bend thick steel will probably limit me to a simple tube cross member. Lol.
The solution I came up with was to completely separate all operations until I could combine them. In other words, put the rear link mounts where they need to go. You'll add a crossmember later for the t case or whatever else. That way you are free in the calculator to use numbers that work with your frame, or as CruiserMatt has said, put your links where you want them then put some frame there.I will definitely be planning out link mount locations and running the link calculator a lot before even ordering any steel. But from the link planning I have done already and looking at other 40s with links, I think I should be able to get a pretty good setup. I do need to figure out exactly where and how I am building the cross member behind the transfer case to look at how the lower frame mounts will look.
We have the exact same goals, albeit mine's probably too long.I'll have a complete engine and drivetrain setup to look at soon enough from *cough @fjdiesel
I will say though, I'm not exactly trying to build a buggy here. I'm still trying to keep it pretty streetable, more of a moderate rock crawler I can drive cross country. This whole custom frame deal is mostly just a workaround to having to deal with issues I'd have with modifying a stock frame.
I can't imagine the Swag press brake could be a bad investment for the money, for a project of this caliber.A lack of a plasma table or press brake (yet) that can bend thick steel will probably limit me to a simple tube cross member. Lol.
Oh believe me, I'll take any excuse to add to the tool collection I have no room for lol. Nearly bought that brake and TMR dimple dies on black Friday but opted to spend money elsewhere.I can't imagine the Swag press brake could be a bad investment for the money, for a project of this caliber.
If you start out right now limiting yourself to "just" a tube and compromise at all, this early, by the time you're done you probably will have wished you bought the brake. Just speaking for myself here, ask me how I know, multiple times.
When you ask about triangulation are you talking about the 71* convergence number? Because that's gobs plenty.First go at placing some links. I copied DJ's link locations from his link calculator he ran and used them as a guide for placing my own. However, it looks like the Y values were too high for the rear frame and top axle mounts? The lower frame mount locations look way wider than in pics and the upper frame mounts don't seem to fit inside the stock frame rails. The front link locations all lined up pretty dang close to where I was thinking of putting them. Straight up copied the panhard for now, will need some adjustment but will probably be similar. I will read up on what is good and bad here myself, but if there is anything glaringly wrong, I'd appreciate hearing about it. Bit limited on triangulation for the rear top links at the current frame width. Good enough? Alternatively, I could transition to tube further forward, and the top links could then go underneath the frame rails.
Looking at doing 14" COs in the front and 16" in the rear right now.
Red squares are locations I got from DJ's numbers (With front top link flipped to pass side), blue are mine. Ignore my mess of lines I made for measuring...
Rear.
Front.
I really believe that is combined. If you look through others’ sheets on there, it looks like it’d be very hard if not impossible to do 40* with each.If I am going to run parallel frame rails, the width is more so limited by tire steering clearance at the front. reading the linked suspension bible, looks like I need to shoot for 40* minimum convergence, I assume that is individual convergence angle for each upper/lower? Or 40* combined? Lower is good there at 45* but upper is only 26*. I will be moving links around to make everything happy and then modify the frame to suit after.
Axle mounts are pretty close to where most put them, mostly playing with frame mounts.
Rear.
Front.
Alright, here is the final expected link geometry. Would love some feedback if you guys see anything you think is funky. Nothing is fully burned in yet, besides the frame side lower mounts. Those aren't going anywhere.
Ah, that must be the latest one. Long thread, hard to find all you calcs lol. Thanks. Yeah that one looks much better, one I saw had a Y of 14" which put it at 28" separation. I'll take a look at that. As for the coilovers, my wheel wells will be moving up pretty much all the way to the top of the tub, should have room.Here is my final geometry.
