I've never heard of any situation where this has happend with a Truetrac (locking in mid-turn). It is not an auto locker it's a LSD and they never achieve full lock under any circumstances. They are very predicatable and I've never had a problem with one in any of the vehicles I've driven including my own.
An auto locker is a whole nother story and I would never say that it couldn't happen with one of these. That's why I would never suggest putting one in the front of a full time awd like the 80 series. You just never know for sure if it is gonna lock up in a situation that it shouldn't.
Kenny:
I find torsen gear type LSD to be very predictable in the front or rear axle, and my post was directed at front clutchpack or front autolocker. I don't agree that a torsen/true trac can't and won't lock up in a turn, that's what it's designed to do. My point is that it's progressive lockup up to actual wheel spin, so by the time any wheels are spinning in the front (and possible loss of control), the True loc has already fully allocated the torque transfer.
My point to the HF2AV is that a VC can cause more understeer with a front True Trac because it can allocate more than 50% of engine torque to the front axle = more understeer. I still agree that the linear application of torque transfert negates any ascription of "danger".
One more thing. There are several production vehicles that come with front LSD's from the factory. Including the Acura TL 6spd, Mitsubishi EVO MR 6spd, Subaru WRX STI, Honda Civic SI, and even the piece of crap Dodge Neon turbo (although it's fast) plus a few more. There has not been a single negative incedent related to the front LSD.
Excellent point. I used to race and DD a Dodge GLH turbo. I installed a quaife (torsen/true loc type gear) LSD in my daily driver without any issues. There are thousands of FWD VW's with quaife front LSD's in them as well. And Quaife makes dozens of FWD applications, more than the True Trac actually.
The old Audi 4000 Quattros used to come with selectable lockers, but they eliminated that in 86. I think it had something to do with rally racing and they needed to have it on production vehicles in order to keep it in thier race cars. Those cars had amazing traction and were so much fun to drive.
Audi history (that I know well
The 4000 quattro used air (vacuum) lockers center/rear through the end of the model run in 1987. Then replaced by the 80 series quattros, these ran torsen center, air locker rear. The center and rear air lockers were in the 5000 series sedans and wagons thru 1988, then again replaced with torsen center, locker rear thru 1994. The v8 flagship ran an electronic clutchplate locker center and torsen rear in the autoboxes, and torsen center/torsen rear. As of 1995, Audi ran torsen center and ABS traction control (EDL) on the front and rear diffs. That is still in use today. Audi NEVER ran a LSD or locked *front* diff in any production quattro. In WRC rally, Audi ran locked all the time in the center. The rear was either locked or clutchplate LSD, locked more common. The front was either locked (always along with center and rear) or open, with only a couple rally's where they used (driver preference) a 20% locking VC. The easiest to drive IMO, was the locked front/center/rear, but it got interesting in tight turns on tarmac.
ST
94 FZJ80 SC
1991 V8 Quattro - Clutchplate center locker - torsen rear
1984 Audi Turbo quattro coupe - air locker center and rear
