SOLD Triple Locked 1997 Lexus LX450 (80 Series)
Year
1997
  1. LX450
Temecula, California United States
Mileage
180000
Color
Tan
Outside Link
https://sandiego.craigslist.org/nsd/cto/d/temecula-1997-lexus-lx450-land-cruiser/7708644247.html
$27,000
Triple Locked 1997 LX450 / Toyota Land Cruiser 80 Series
Clean California Title in hand
Registered through September 2024
180,000 Miles
Owned by me since August 2021
Originally a California vehicle, garage-kept in Aspen, CO for a time, then on to Texas (prior owner who did some of the modifications), then back to California with me. Undercarriage is solid. Selling because we’ve moved and I'm not able to put the truck to use anymore.
A TON of maintenance has been done (way beyond baselining). An incredible modified and tight 80 series Land Cruiser with low miles! This truck is adventure ready and loves to explore!
Modifications:
-3" lift front and rear (Dobison 3” IMS)
-Re-geared 4.56 (to accommodate 35” tires)
-ARB onboard air compressor
-ARB air lockers front and rear (factory center diff lock in 4 Low)
-White Knuckle Sliders (with Solve Function front wheel flare caps)
-TJM front bumper w/ 9500lb Comeup winch
-Viper rear bumper with swing arm with full size spare
-35" Wildpeak AT tires (315/75R16), including spare only 16k miles on them.
-Diamondrax basket style roof rack-Laser Star LED Fog Lamps
-Jensen backup camera, Audio, Bluetooth, GPS.
-Updated Pioneer speakers
-Will be sold with OEM power coated wheels
Additional Investments:
-Dash Cover with storage pockets
-Seat covers (all 3 rows), imported from Melvill and Moon in South Africa
-Spare key, cut at Lexus dealership
-Updated Sun Visors with LS430 upgrade (using Solve Function visor clips to ensure swivel and fit)
-New Front and Rear floor mats
-New Battery - DieHard Platinum AGM (35)
-Spare Tire Cover
-Refreshed Center Console cover from Land Cruiser Heaven
-Wits End center console and cup holder liners
Maintenance in my ownership (since Aug 2021), all work done at specialized TLC mechanics:
-Replace Air Filter
-New Battery Ends
-New Complete Rear Brakes
-Fresh Diff fluid front and rear
-New Front Knuckles, Bearings and Full Brakes
-New Radiator
-New Transmission pan seal
-New Valve Cover Gasket
-New EGR Modulator
-New front crankshaft/oil pump seal
-New Rear Main seal
-New Heater Hose-New Heater Control Valve
-New Heavy Duty Fan Clutch
-New Rear Pinion Seal
-New Upper/Lower Oil Pan gasket replacement (and oil change)
-New Transfer case speed sensor o-ring
-New Power steering pump leak repair and new hoses
-New Panhard bar bushing in front and rear
-New Dobison Rear upper and lower control arms
-Tom Wood’s Double Cardan front drive shaft (to better accommodate new suspension)
-Head gasket replacement
-New rear wheel bearings
-New brake master cylinder with full system brake fluid flush
Known Issues:
-Single dash crack above drivers cluster. Was there when I purchased, I have kept dash covered the entire time I’ve owned it.
-Front seats -wear on drivers seat, cracked passenger seat
-Small dent between cladding and rear tail light on rear drivers side panel. Prior owner stated they purchased it this way. I keep the truck clean so there has been no progression of the issue.
-Slight patina on hood paint
$27,000
180,000 Miles
Modifications:
-Spare Tire Cover
-Replace Air Filter
-New Battery Ends
-New Radiator
-New EGR Modulator
-New Rear Main seal
Known Issues:
I’m currently trying to outfit my 97 lx450 with Melvill and moon seat covers. But I’m only seeing the landcruiser 80 series option on their website. My understanding is the seats vary slightly (standard Toyota vs Lexus lx450) in proportions. May I ask how you ordered yours? What options did you order from Melvill and moon?
