- Year
- 1997
- Vehicle Model
- 80 Series
- Mileage
- 212900
- Color
- White
Great condition 1997 Lexus LX450 with significant upgrades and extensive maintenance. In great running and operating condition. Highlights include: triple locked, 24 gallon auxiliary fuel tax (~49 gallons of capacity), ARB bumpers front and rear, 4 inch lift, SLEE rock sliders, very nice interior condition, OZ-USA spot/flood combo lights, new brakes, new AC, PHH fix, D light works, rear camera, winch. Lockers exercised every few months. I've owned this since 2020 and it was my daily driver in Houston for about 3 years.
Price: $33,000
Issues: throws a PO401 code occasionally (haven't addressed the EGR yet), passenger side mirror need to be replaced (it moves up/down but not right/left), I recently noticed a small rust issue developing around the windshield, passenger side (see pic).
I kept a running list of things done to the truck. Some of the items at the top (suspension, ARB front and rear bumpers, rock sliders) were installed prior to my purchase. I have many of the receipts prior to my purchase and all of them since 2020.
Price: $33,000
- SLEE - 4" Front Coil Spring - Medium - PAIR
- SLEE - 4" Rear Coil Spring - Medium - 80 Series Land Cruiser - PAIR SLEE - [4" Lift] - Remote Reservoir Shock. Front.
- 10.8" Stroke, 15.2" Com, 26" Ext. 14MM fixed pin top and bottom.
- LH and RH Bracket and 4 Hose Clamps (2.75").
- OME Steering Stabilizer SLEE - [4" Lift] - Piggyback Reservoir Shock. Rear.
- 10.8" Stroke, 15.67" Com, 26.5" Ext. 14mm Fixed pin top, eyelet bottom.
- SLEE - Billet Front Control Arms - - 6" Lift - Coated, no bushings - PAIR Bushing - Control Arm - Front Axle
- Bushing - Front - Lower Control Arm - Frame Side - 80 Series
- SLEE - Rear Swaybar Drop Brackets - PAIR
- SLEE - 2" Front Swaybar Drop Blocks - PAIR
- SLEE - 2" Rear Bumpstop Drop Blocks - PAIR
- SLEE - 2" Front Bumpstop Drop Pucks -- PAIR
- SLEE - Front Adjustable Panhard Rod - Complete unit with new bushings. LHD
- SLEE - Rear Panhard Rod - Adjustable -
- ARB Adjustable Upper Control Arms -
- SLEE - Front Double Cardan Shaft - Reconditioned hard parts with all new moving parts.
- Brake Line Kit - Stainless - '93-'97 Land Cruiser (3 pc frame to axle kit)
- Breather Extension Kit
- Emergency Cable Bracket Spacer
- KIT * SOF 4" Premium Lift Kit for 80 Series Land Cruiser
- Exhaust (2020)
- o2 sensors (2020)
- 24 gal aux fuel tank
- 33" tires (2020, approximately 30k miles)
- New head unit
- Rear camera
- Tailgate storage system
- Rear storage box in rear. Removable.
- New light fixtures all around (Depo headlights, taillights, turn signals, corner lights)
- LED interior lights
- LED lights on rear hatch with switch
- New wiper linkage and motor
- Steering shaft seal at floorboard,
- Spot/flood combo light on the arb bar: 80w High Ouput DRL 7" Round OZ-USA® LED Light Combo Spot + Flood Beam with DRL Function
- Separate switches in cab for DRL and Floods
- Right rear door lock actuator,
- 2 new window motors,
- New antenna and motor, manual instead of auto Loud gear grinding noise after power antenna lowers. - https://forum.ih8mud.com/threads/loud-gear-grinding-noise-after-power-antenna-lowers.1187884/page-2
- Knuckle rebuild
- Wheel bearings
- Distributor seal
- Lower pan seal
- Trailer 4 pin rewire
- Hood hatch struts
- PHH
- Temp sensor
- Alternator
- Recent brakes, front and rear
- Parking brake fix
- Rear hatch struts
- New fan and fan clutch
- New air vents
- OME SD24 Steering Stabilizer
- D light fixed
