Agreed you'll want to make sure the springs you installed are at the right sides first.
That said, I think you'll want about 15mm worth of trim packers, rather than try to make up for the full difference.
I do have trim packers installed on my LX for a different reason, to augment AHC for higher loads (LRA tank), then AHC lift. But the spacers/trim packers, parts are the same. I have 2x 10mm spacers on each side, or 20mm of spacers total on each side. As I upgraded in stages, I added 10mm, and then another 10mm spacer. The install is pretty easy.
I have one spacer above the spring isolator (between chassis and spring isolator), one below (between isolator and spring). If you're not sure, I'd say start with a 15mm trim packer and adjust from there.
