- Thread starter
- #21
Is it safe to assume you want to buy, as opposed to build, your tow rig?
Yes. I have PLENTY of projects on the table already.
With a truck, you can get something like this and still pull a trailer: http://www.livinlite.com/images/_products/camplitetc/cltc/11cover.jpg
First he says he wants to buy a truck, then he says he wants to build a pop-top suburban![]()
Ok... so how about an enclosed trailer that I can also use as a camper when the truck is out...![]()
I'm considering going over to the dark side and trailering my 60 rather than driving it when headed out to wheel... I'm convinced that a 10k rated dual axle with brakes trailer is the ticket. My question is: what are people using to pull this sort of load? I'm in the Northeast US so hills are a regular part of the equation. I know there are a million solutions...
I do exactly that...pull a 3k metal deck dual axle car hauler trailer with my 5800lb FJ60... I do so with a 2500 HD GM pickup with 4.10 rear and 6.0 gas engine. It does very well. I have a regular cab long bed....long bed truck has the larger gas tank...almost 40 gal.
Trailer had dual 5200 axles with brakes on each (10.4 trailer). I have weighed both the empty trailer and my fj60...these are the actual weights.
I had a 02 suburban with 3/4 ton and 496 engine...it worked fine too, but I wanted the utility of a pickup over a suburban. I suburban is a great tow vehicle but some of them have the electronic adjustable ride (shocks) which are expensive if need to be replaced. I like the 496...but the 6.0 gas engine performs well and yet it only gets about 1 mpg better in demonstrated fuel MPG . THe 6.0 gas engine is pretty impressive....and I think the only way to order a 2500 HD or find one used...is with the 4.10 rear end. With a 496...stay with the 3.73, some year model GM pickups came with 496 too.
