- Thread starter
- #621
Found that quick hinges interfere with older body openings. @2fpower had clearanced mine with a grinder but wanted it a bit cleaner. So took them to @kc_chevota 's for a quick run thru the mill. then a quick blast and paint. Cleaned up a spare 60 series transmission mount and put everything in epoxy..
After the epoxy was a bit of single-stage and dry time. Dropped the windshield frame down and wired up a Gentex GHSHL4 mirror. I could have put an OEM ish type mirror there but this has homelink, Compass and a camera built in. Really just wanted the homelink to avoid garage door openers flying off visors.. the two phone cable things are for the ham radio head that i plan on mounting above the mirror where the original mirror mount went on the windshield frame.
My problem I ran into after getting everything installed again with new weather-stripping is the doors won't shut. I gave up after the football game and will attack the door adjustment later. I did proactively order the thinner weather-stripping from Cityracer for the doors. At this point in the game I'm all for an easy fix.
Once the doors can shut, I can calibrate the speedometer and the Compass in the mirror.
