Tips for cleaning original floor mat? (9 Viewers)
Bozeman, MT
Looking for any tips on cleaners and what to do and or to avoid when cleaning up an original floormat?
Any products you guys have had good luck with. I was thinking of bleach white tire cleaner as it restores the look of old tires... not sure if it is too harsh for a floor mat?
I am open to suggestions. Mine seems to be getting brittle and I want to help preserve it while maintaining it. Never mind the huge burn mark! haha
Rear mat... looks like a big burn on the other side.
I spent some time on the rear mat. I think I instantly got some tears as I moved it around. Not sure if it is too brittle or if the chemical I used on it was too much? I used Purple Power and a pressure washer at distance to wash it off. This is what is making me a little more cautious with the front and mid mats.
Before:
After a good scrubbing with a brush on the end of a drill and purple power cleaner it came up pretty good but it seemed to still be brittle. Thoughts?
There is a large amount of information on google explaining why rubber hardens with age, which you can read for yourself. Not much you can do - but the sort of popular method is a mixture of wintergreen oil which requires the entire mat to be cleaned thorougly.
To clean it properly you'll want to use a pressure washer, large ultrasonic, pressurized steam, etc. Otherwise you're stuck with scrubbing with a mixture of hard/medium hard bristle brushes, bathtub and your favorite non-solvent cleaner is the best way to clean safely.
Solvents will degrade or damage the rubber.
I just cleaned it with washing up detergent and hot water.
i bonded some sturdy canvas onto the back where it was really bad - hopefully that holds it together for a while longer and stops it getting worse.
I had a similar hole which I patched with an offcut of grey lino from a local flooring shop.
Drew, if you screw it up, I might know where a replacement is located
I have no help to give, but I also have the same problems and concerns with the mats out of the 45, except I have the added problem of contact cement where the PO glued a cover mat all over the OEM floormats. So, if any body has help for that (as well as dirty/brittle), I would be eternally grateful.
May want to try the Aerospace 303 for cleaning the rubber mat.
FWIW: on smaller rubber items like door & window seals, I use Gummi Pflege Stift to condition them.
I have the same problems and concerns with the mats out of the 45, except I have the added problem of contact cement where the PO glued a cover mat all over the floormats. So, if any body has added help for that (as well as dirty/brittle), I would be eternally grateful.
