dear fellows i want to adjust my TPS of hdj81 1hd-ft 24valve because i rebuild injection pump and nozzle but now lack of power in initial gears.accelerates slowly like someone have applied hand break and black smoke as well.
i attached voltmeter to TPS positive terminal giving 5.05volts and then found ground and other wire which leads to ECU.
when i checked voltage with no accelerator pedal pressed it was giving reading of 3.67v (no accelerator pressed)
slowly pressing accelerator pedal the voltage started decreasing slowly till it reached 0.92v with full accelerator pressed.
Can any one tell me what should be the voltage with no accelerator pressed ?
Are the above mentioned voltage alright?or i have to adjust TPS?
