Well ive read every thing i can find about the common vacuum leaks and I'm still having trouble.
I recently installed a trollhole card and dui ignition just because i wanted to update that stuff. And the truck ran as bad or worse than with the stock setup. I finally started finding small vac leaks and fixing them as i went. It's running much better but still has a stumble and "shaky" acceleration. So i pulled the intake and checked for warps and cracks and none found. I have an old header from way back so i used 2 felpro gaskets sandwiched together. Back together and its a little better but still not 100%. Yesterday i called @Trollhole and he walked me through the carb tuning process just to be sure i had it write and it is tuned correctly. Ive sprayed carb cleaner over the whole damn truck at this point and I'm not getting the slightest rpm increase anywhere. I'm at my whits end with this. It idles perfectly smooth but driving i still have the off idle stumble and the sort of shaky feel as i accelerate. But if i pull the choke out its runs and aclcelerates off idle or off of a gear change smooth as silk. Ive sprayed all over the intake top and bottom, no rpm change. I just cant seem to figure this out.
Any help would be greatly appreciated
