1974’ FJ40 Vacuum Questions
Utah
I’ve removed all emissions on a 1974 FJ40 and can’t recall exactly how I need to hook up vacuum for the carb diaphragm, and the vacuum advance. I’ve got a vacuum port on the bottom plate below the carb, and 2 coming off the intake manifold. Need to run one to the vacuum advance, and one to carb diaphragm. Any help would be appreciated. Thanks.
The carb diaphragm goes to the port driver side under the bracket, vac line to dizzy comes off passenger side carb base.
Cap the manifold ports or run one to a vacuum gauge.
EDIT: That's a vacuum retard dizzy, best to not hook any vacuum to it.
Mmmm…. I don’t have that vacuum port.
I had a Guru install that port during a rebuild.
Nice, any way to do it with what I’ve got? Is that manifold vacuum that much different? I guess I could get a vacuum gauge and see. Just trying to make it easy.
You could probably drill your own hole. But it has to go in at a certain angle to a certain spot. The Pros use a special jig, as I understand it.
Ported vacuum is very different from manifold vacuum. I have a gauge for each in dash...
What pighead said ^^^
Carb choke diaphragm connects to driver side bottom of carb body. Just cap your distributor diaphragm as it's vacuum retard, not advance.
Here's mine for reference. This is a 71 carb I believe.
Good to know. Thanks for the info. I’ll try running the dizzy without vacuum and see what it’s feeling like.
