The Ultimate A/C Thread For Pigs! (Air Conditioning)
Sanden’s mount horizontally. Modern style of compressor since the early 90’s.
Heh heh, you said “Mount horizontally…”
Sorry, I will go try to add value somewhere else since I am not contributing to the technical content of this thread…
This is the type of compressor and this is the mount on a 2F, Iam hoping I can find one with the larger V belt, groove.
Has anyone used a kit like this to replace the factory hoses for the AC? It seems the fittings on my factory AC is all -an fitting. Not sure about the orings, still in planning stages.
So @J Mack , will these fitting work for 79 factory Toyota AC?
I believe the switch from R-12 to R-134a began in the late 1980s early 1990s.
Look for R-12 to R-134a adapter fittings "45° to O-ring" and then you could replace all the hoses with newer barrier hose and fittings but unless you're updating your entire system I would stick to the R-12 system and fill it with the R-12 Eco safe refrigerant..
