The official part number request thread (1 Viewer)
Thanks!! This helps. That seller seems to have a good selection of LX stuff. The part number is now added to my saved searches on ebay.
That's a bummer that it's common, I don't remember it being lifted when I picked up the LX last week. I assumed it was due to the top of the door getting wet but I could be wrong.
MIne is lifted and cracked in the exact same spot. And 4-5 of my wood pieces have started delaminating.
Has a part number, but no one shows it available. I suspect it would be expensive if you found it. Probably best to try to repair the one you have. This is pretty common though, so any used part might not be much better than yours.
Interesting.. those numbers aren't coming up in the parts system I have access to.
Going to do a transmission fluid drain/refill on my 2021. I'm assuming there's some gaskets that need to be replaced. Any part numbers for transmission fill port gasket/washer as well as the drain and overflow tube port? I know the pan drain and overflow tube situation changed in later model years of the 200. Thanks!
I have actually had trouble with this one in the past, the diagrams aren't entirely clear which of the three candidates is the fill port.
I do know the drain gasket is 35178-60010
The fill o-ring is either 90301-15004 or 90301-11030
There is info buried in the big fluid exchange thread on the 8-spd.. maybe a little more specificity there?
FYI you'll need 2 of the drain plug gaskets, one for the pan drain, and one for the fluid check plug.
8 spd transmissions do both operations from the same port.
Huh. Did not know that. Thanks, sorry for the distraction.
Yeah, it's what a number of manufacturers are doing now.. and IMO less convenient than what we do on our 6-spd. But not horrible.
And no worries. It's all education.
Well perhaps I'll order all of the aforementioned part numbers and see what ends up fitting for the transmission. Appreciate the input from you guys.
iirc you will need the following assuming you're NOT dropping the pan:
90301-15004
35178-60010 (x2)
I used these for a 2021 transmission fluid exchange. Though to be sure (and not have to make a run mid job), either search mud for confirmation or just buy two of each of the gaskets above.
90301-15004
35178-60010 (x2)
Not going to drop the pan. Thanks!
2013 LC - US Spec
Headlights outer lenses fogged over from the sun - What are the assembly PNs for the L&R headlight buckets minus the lights or electrical components (electrically fine)
2013 LC - US Spec
Serviced as assemblies only.
RH, 81145-60F50
LH, 81185-60F50
Published list price, $896.20 a copy.
2013 LC - US Spec
RH, 81145-60F50
LH, 81185-60F50
Yep, even at that price they’ll actually come without ballasts or any of the bulbs but the leveling motors and LED internals will be in there.
I waited for a sale and put new buckets in my 2013 earlier this year.. so worth it.
Can anyone weigh in on whether these two connectors are the same or possibly a supercession?
90980-12A49
90980-12A59
(last two digits are 49 vs 59)
The use of 90980-12A49 is a female 6 pin connector for the front camera on a 2016+ Land Crusier. Toyota calls it a F connector.
From web searches, the 49 and the 59 look like the same part.
90980-12A49
90980-12A59
Did you get the 12A49 directly off the connector? That number isn't coming up in the systems I have access to, and not much coming up in an image search online either. In the diagrams 12A59 is used in dozens of vehicles however, including your 2016 cruiser, on the front and rear camera.
Nope. I'm a dope and messed up the part number. The 12A59 is what is stamped on the connector. Sorry.
Thank you!
In the EWD, it is marked A49, so that may be where I got turned around.
That makes sense. The EWD is like learning another language..
