The official part number request thread
Best call A Lexus dealer with your VIN. Uber expensive trim and you don't want to be wrong.
I wouldn't blame you either way. Doesn't seem anyone has ordered it before and the cost of repair/replacment from an interior shop isn't that different.
2013 LX570 w/ ivory interior.
Part number(s) for lower front driver side (LH) seat cushion and leather cover. I believe it's offered as an assembly (with the heater unit installed) but hoping someone can confirm. Suspected assembly part numbers in my other thread here.
FYI your link doesn't seem to be working.
Also (as usual) Dan is on point.. there are a bunch of numbers for different options and build dates and this would be an expensive one to get wrong, especially for the leather cover.
Hyperlink fixed.
Can either of you at least confirm what your system shows for the following part numbers? They look like assemblies but I cannot find much on them. I still planned on calling a lexus dealer before ordering.
Option 1 (with aniline leather) --> 71001-60K80-A0
Option 2 (without aniline leather) --> 71001-60K60-A0
Hyperlink fixed.
Those numbers do appear to be for complete lower cushion/heater/cover assemblies, with and without aniline leather, respectively.
Appreciate you taking a (cautious) look in your system. Do you happen to have any notes stating whether it's for the driver or passenger side? Are there any other "assembly" part numbers showing as related items?
Looking for a PN for the"air bag cut off switch cylinder assembly" that installs in non-US LC's (similar to the extended cab taco's it is a mechanical key switch cylinder). It installs on the exterior facing portion of the glove box/dash assembly trim (near where the door closes flush on LHD rigs). It connects to connector F38.
I dug through a few markets and years and didn't see anything other than the RSCA cutoff which I'm pretty sure isn't what you're looking for.
Without more specifics on the intended market and year this may be really difficult to find.
99.9% sure it is PN 69065-12460 and it is a common part to RAV4/Yaris/and maybe single cab tundras?. I'll add one to my next UAE order and give it a try for $40
Sorry I missed this. Those are for the passenger side. The diagrams for these are very complex, with tons of small parts and clips and harnesses, so any other assembly part numbers is a really loaded question.
For the record I don't see an equivalent assembly for the driver's side, only separate cushion, cover, heater, etc.
Ah, yeah. Looks like only south african LX570s came equipped with that, at least in the 200-series. A whole lot of other toyota models got it.
Request front UCA, LCA, inner/outer tie rods, and boots/clamps for tie rods for a 2013 LX570. Are they the same part numbers for a 2013 LC200?
At least for 2013 yes LX and LC are the same.
LCA assembly
Left 48069-60030
Right 48068-60030
UCA assembly
Left 48630-60030
Right 48610-60060
TRE
Left 45047-69146
Right 45046-69236
Inner (left and right are the same)
45503-60030
Boot
45535-60020
Clamps
Large 90460-76001
Small 96134-52600
Does anyone have the part number for the plastic inner fender liners for a 2016 Land Cruiser? I trimmed mine back for aftermarket bumpers, but am slowly going back to stock and want to replace these.
Left 53876-60130
Accessory flap 53852-60090
Right 53875-60160
Flap 53851-60180
The flaps will need two screws 90159-60496 each
There are a few other assorted screws and clips.. probably best to attack them as you figure out exactly what you need.
Left 53876-60130
Right 53875-60160
Flap 53851-60180
Thank you!!
Driver front seat belt assembly (retractor/belt) in ivory. 2013 LX570
Call your local dealer with your VIN. There are multiple possible part numbers for this application.
The two dumbest people here would be the one that supplies a number and the one who relies on it.
I use this as a first pass before confirming myself and the dealer. If you believe parts counters are 100% for this stuff and significantly better than enthusiasts you're mistaken.
Apologies for the mistake of using this thread for it's stated purpose.
Even the most dialed-in enthusiasts do not have access to the factory catalogs (unless they work in a dealer parts department). Any trained monkey at a dealer parts counter can open the catalog and filter what you need, based on your VIN. Since I am retired and I no longer have access to the factory books, I can narrow it down this far...
Screenshot 2024-11-26 at 17-49-40 71-52 SEAT BELT diagram 2013 LEXUS LX570.png
There are 8 possibilities.
