I would like to run it up on a dyno of course, just for consistancy. I've got no need for bragging numbers, but to be able to repeatedly replicate the same conditions and make small but regular changes would be so nice!! The authorities that rule our freeways must sure be getting sick of me pulling on and off it...!
I'm sure both sides of the pond can agree that the end result is the main thing, and how you go about getting there is your own business..?!
My intention was to set max fuel at max point of the pin, which got a bit ugly at the time, but I'm pretty sure I roughly got the pin to fit full travel when I was setting max fuel. But you're right, I have a current test drive that I've got a couple of points of reference on, so I can check it. Been a bit busy but trying to get it done via measuremnet but as you can see, I kind of shot myself in the foot a while back (pre Gturbo) when I was trying to get more fuel in low down. I've ground the off boost flat even shorter, so to get the follower to sit on the off boost flat, I've got to lift the pin even higher, which means more spring tension to get it to start to move. Which doesn't help me getting off the line.
But setting the smoke whilst having the trailer on means it pretty clean without it.
I've always reckoned the med range is a bit doughy and lean tho. What do people thing about grinding in a slight concave to get some more fuel going thru the midrange?
