- Joined
- Jun 30, 2013
- Threads
- 21
- Messages
- 168
Great. Thanks guys!
I may have confused you with the pump build info. History as follows:
2008: bought truck. Pump tweaks unknown. Rebuilt in 2002. Went bloody well. Blew some soot down low and found EGTs a bit high on the highway. Economy pretty good 11-12l/100.
2010: got pump tuned on dyno. Economy improved. Tuner claimed there was not enough 'low end'. Picked up ~15hp. Ran for 80k. Did 6 month trip with 3.7ton. Reasonable economy; new injectors.
2015: got a bit smoky so pump rebuild. 'Modded' to late model pump specs. Set on bench. A real slug dozen low. Almost no smoke throughout range.
So... I should turn cam back to minimum and perhaps try a little less spring pressure? I have been adjusting star wheel through side but it would be easier to remove diaphragm. Do I just need to take out the spring in the front side to get the pin back in?
Will try and fit AFR ASAP.
Cheers!
Dave
Cheers!
Dave
We cut the ramp in at exactly 1/4 of the pin...say, "3pm"... allowing me to use either the "stock, oem" face or the more aggressive modified face.
