Builds "The Milk Truck" FJ45 Preservation Sorta (1 Viewer)
Great work, man. Looks factory. You'll appreciate all these little details once it's all together.
I have been binging on Hiltz Auto Company on YT. His ability to mix and match toward art is amazing. Reminded me of it.
Thanks for the nice comments. Feels good to have been able to make this piece my self and learn something new in the process.
@ceylonfj40nut I will have to look up Hiltz Auto and see what they are doing there. I learned the form making watching a video from Makeitkustom.
Carl Fisher really does some cool stuff and I love his videos! Check out Metalshaper and Wray Schelin on Youtube as well. There is a massive amount wealth of information and skills they're giving away on those three channels!
the corners look amazing. Was there any heat needed??? I don't see any scorched wood, so I assume not.....
Any tricks, that looks great.
@2fpower
The link above is the video I watched to learn how to do it. Honestly it was easy, I just took my time. I built my panel out of 14gauge steel and didn’t have all the tools he has, so I used a small sledge hammer to start bending the panel edges. After I had the edges all turned down I used the flat side of a ball peen hammer to finish it. When working the edges down I just made sure I worked all the sides down consistently at the same time. No heat involved.
On my bottom form piece I didn’t rout the edges with a router. I wanted a sharp bend, so I just used a block sander to smooth and take the rough edge of the form.
The bolt heads that clamp the form together hold the bottom edge off the table. I found my bottom form started to crack so, I stuck wood pieces under the edge of the form to support it and that worked well. I then clamped it down on the table to keep it in place.
I used 5/8 fiber board and after one use my bottom form was done. In the video he uses 3/4 or one inch. I expect that would hold up better.
Watch that video it will explain it much better than I could.
It takes a while and your arm will get tired. That is the first time I tried it and it turned out great. It is not hard.
@2fpower
That is also like the formula to a new drip rail. Awesome!
I ordered a vintage air surefit heater/AC unit a while ago but I swapped the condenser for a universal one to accommodate the steering cooler. The condenser came before the rest of the unit so I started fitting it.
While fitting the condenser I decided the Setrab steering cooler was too deep at two inches and that I really needed something closer to an inch. Finding a one inch deep steering cooler that flows across with an outlet on each was not easy. I searched the internet for an aftermarket option but didn’t find any thing except a Mopar unit for a charger or viper. I spent a few hours walking around the junk yard just looking at steering coolers.
I bought two out of mini vans and one out of a Challenger. The unit from the Challanger looked like it could work but I wanted more than just the single row. I figured the three row Charger unit I found online would fit perfect if the measurements were similar.
I ordered it and it looks like it was just what I needed. I probably overthought the cooler but I happy with the way it turned out.
I made a few finishing touches to the cooler mounting and the power steering pressure side hose. I use my spot welder to add some capture nuts inside the radiator support to make mounting and servicing the coolers a lot easier. The high pressure hose for the power steering got secured with two clamps attached to the cooler mount I made running across the front. I am hoping this works well and will be solid enough not to chaff the hose. I may add some wrap for additional protection, thoughts?
I am just waiting on the new radiator to arrive before I am done with the radiator support. Then I can repaint it and move on.
What type of spot welder do you have? I have quite a few weld nuts to install for my '71 FJ40 build, 6mm like the ones you showed, 8mm square, 10mm hex, and 7/16-20 UNF square (for seat belt mounting hardware). I bought the 6mm nuts more than a year ago, IIRC those were from McMaster-Carr, same place I ordered the other sizes from yesterday. So a spot welder would be ideal for the 6mm hardware.
Where do you purchase the weld-on nuts?
I just ordered quite a few (^^^) from McMaster-Carr yesterday, they'll be here tomorrow. More than a year ago I bought a package of 100 just like the ones pictured above. I'll have quite a few extras of each size, I'll let you have them if you're not in a hurry.
I ordered mine from Amazon but I am sure they can be found other places like McMaster-Carr as @4Cruisers pointed out.
The spot welder I bought is made by Miller. It has been nice to have for simple clean work like this. You could easily mig weld the capture nuts on but I like try to keep a factory look as much as I can.
Wait: you have a manufacturing line style spot welder? Just to build one cruiser?
Am I missing something?
This is the spot welder I bought with a couple different length arms. Technically I bought all three of my welders to build one truck but they have all been used on other Land Cruisers I worked on to help support this build.
I personally would rather spend my money on tools I get to keep and learn a new skill with than just pay someone else to do the work for me. This is the approach I have taken for as much as I possibly can with my build. I have taken advantage of a local machine shop to make a few trick pieces or modifications for my build but other wise I am trying to do as much of the fab work on my own as I can.
When I initially bought the spot welder I had started my 45 build with an entirely different truck which I sold after acquiring the 45 I am building now. I didn’t have a SWB bed at the time and figured I would just build one. I bought the spot weld at that time specifically to build my own SWB bed. I don’t have to do that now but the welder sure comes in handy.
Nice. Very nice thinking. I knew about your previous trucks but didn’t realize the infrastructure and tooling investment.
GOVT teet must be nice…. :flipoff2:
It is not that nice. :flipoff2: I flipped a few rigs, parted a few out, and whored my services out for some others. I could easily be done with my build if all my efforts could have just been spent on the one truck. Not to mention halfway through one build I sold it and started all over.
I have learned a lot along the way though.
I have used this one for several years. Takes some time getting used to how long to keep the trigger down, but does a great job.
saves hours of work..
Here is a non-weld-on version (M6) that I bought from my neighborhood Ace. It has a captive mechanism. Black oxide finish. I had to buy one because I thought that I could have a wing-it solution if I ever brake free a captive nut, and want to repair it from the front face of the part. I would modify it to minimally weld it on, and cut the rest off the rest.
I have been repairing holes in the floor and a few rusty spots on the tub. Nothing picture worthy but I am making progress.
I did get the mounting flange for the transmission cover cut out and welded on. I cut it out with some mounting flanges I bent up to position the cover correctly over the mounting flange. I used the the spot welder to secure the pieces in place then welded them together all the way around. I went back and cleaned up the weld after. It turned out well but with enough character to match the rest of the 45. I intend to coat the cover and floor with lizard skin and bed liner, so it should look pretty good when it is all done.
