- Thread starter
- #1,041
Okjust run the alt to the battery.
ok. put new alt on. ran new 6 gauge wire from Alt to battery and ground from Alt to frame. And Nothing Same. This makes absolutely no sense
. Was able to upgrade to new Sniper 2 . New Sniper 2 does not Plug into old sniper harness
. Made new Harness out of old one . Took my fuel pump out and put new pressure Regulator in . Added gauge to see actual . Made new SS AN-6 fuel lines . Fired up and running good , But not charging
. Checked ,rechecked and checked again . Took New old alt out and took back and exchanged for new alt . Same nothing . Took back apart check all grounds where clean . Took back apart and took back to store to make sure the Alt was indeed good Alt was good .
. Reinstalled and added new Alt to Batt wire 6 gauge added 6 gauge ground wire to Alt . and Nothing Cranked tension on belt down and got a little 12.6.
. ok First test drive
. But i believe we have it narrowed down to the fuel pump . Runs great but when you get on it it goes lean and stumbles . I had installed a fuel pressure gauge and can see it drop when i get into the throttle hard . Not enough Fuel making it lean out . She needs More fuel . as Frustrating as this is i will say the Holley techs have been very helpful and are sending me a new pump and filters . I also noticed my pump had a different sound to it . I cycled it so the tech could hear . He agrees its a bad bump or i guess there is a plastic line that can get a crack in it ? If i am easy on the gas it runs fine . I can move it around for now so i am good . On a positive Alt is good No I have a In tank Returnless Pump. In Hindsight this very well could have been 1 of the issues with the sniper 1 . If this was not ment to be a crawler i would 100 percent just run a carb . But i am confident that i have narrowed this down and have found the issue now .awesome job sticking with it! Is the fuel pump inline?
its is supposedly it sucks fuel in it ? well for some reason its not . with it off it runs like a rapped apeI've never seen a "strainer" that looks like that. Usually look more like fine mesh. That looks like more like an absorbent pad.
