The Final Frontier-OE hardware production timeline
65swb45
Elder Statesman
Supporting Vendor
Website
www.marksoffroad.net
I posed the question of whether anyone had seen a repository of information on OE hardware manufacturers and approximate manufacturing timelines. Not much response. But while the majority of folks are content to reassemble their projects with anything that is JIS correct, there is a significant subset of people who are interested in what is period correct for their rig.
I’ve been wrenching on Landcruisers for five decades now, and have amassed literally tens of thousands of pieces of OE hardware across the entire spectrum of production. IOW, I’ve seen a lot. But I didn’t pay a huge amount of attention. I have this general sense that the earliest hardware (M6&M8 for the moment) was all clear (silver) zinc, and that somewhere around 1967 there was a wholesale change to yellow zinc. Also I have a sense that the earliest hardware had a flat surface with raised numbers, which moved to the more familiar double ring around the same time as the change from clear to yellow.
BUT, and this is a big BUT, it’s highly doubtful that Japan only had one hardware manufacturer, or that only one manufacturer was supplying Toyota. I have not seen if the Japanese hardware industry developed a database like we have domestically, to determine the exact origin of hardware. This seems to be an area that is ripe for speculation.
My personal hunch is that there was more than one supplier, and that the color change was implemented at different times by different companies. Since most of what we end up looking at is rust, the clues are harder to decipher.
So my purpose here is to gather datapoints from those of you who have been able to harvest and successfully reuse OE hardware to supply: M size, head configurations, production dates, and OE color if you know. For example: M6, raised number, 10/64, clear. Or M6, double ring, 10/68, yellow.
I thought of trying to start an OFFICIAL HARDWARE thread, but I think it would get messy real fast, as real life input is often messy. So I think it would be better for now to just throw the gates open, and to cull the raw data into more defined timelines down the road, in a different thread, when we have several hundred datasets to work with.
Here’s a little M8 sampling to start with. Notice how the first five, even though they are all early raised head are different. I’m sure the difference in the size and shape of the numbers helps indicate different manufacturers. But the fact that the two in the center are yellow zinc, yet from what I have always considered the ‘clear’ timeframe, that was a surprise even to me. How? Because I am only now starting the process of dragging dozens and dozen of boxes of accumulated hardware out of their hermetic burrows in my shop and bringing them to the confluence!
Ultimately, this will be a huge, group effort, that will hopefully continue to bear fruit long after we’re gone. It would be nice if you hit the like button if you approve of the effort.
There were tons of companies providing Toyota with hardware. And, more importantly, hardware had to ascribe to JIS which indicates that the markings and other aspects of the hardware all had to conform to generalized standards vs. only what Toyota needed/wanted.
Some hardware companies for Toyota:
Aoyama Seisakusho Co., Ltd.
Ito Kinzoku Kogyo K.K.
Sugiura Manufacturing Co., Ltd.
Topura Co.,Ltd.
Meidoh Co., Ltd.
Tokuhatsu Co., Ltd.
Fuserashi Co., Ltd.
Aichi Steel Corporation
Toyoda Iron Works Co., Ltd.
As a point of reference, the 10-digit part numbering system with classification of hardware as semi-standard and standard parts was instituted in October of 1963.
I think THAT point marks when the numbers moved definitively to the center of the head. Thank you for that.😊
I have purchased MANY new fasteners for my 73 from Toyota. Not one is yellow. Possibly they used cad plating at some point but not yellow chromate.
That would have had so much yellow cadmium plating on it, hardware, brackets..the gas pedal assembly.
Just because a bolt is silver zinc today doesn't mean it wasn't yellow cadmium in 1973. Right?
Correct, cad is so toxic, not used much anymore, maybe back in the day. I have seen others comment on here that Mr. T did not use yellow hardware. I agree stuff like the accelerator pedal was yellow.
Just bought this rear engine hook/hanger bolt for my 1977 FJ55 a few weeks ago.
64 years later, still shows signs of yellow cadmium and the red paint that wasn't quite fully cured.
I think the yellow stuff is hexavalent chromium, not cadmium. Both nasty though!
Lots of bolts on my ‘78 are yellow and white.
100% cad.....this had been sorted out decades ago.
So what kind of info would be valuable in this thread? Are we looking to document the kinds of fasteners we find on different parts of our trucks over different years, research & track down OEs, determine what modern replacement options are? It would be helpful to be specific... I've been going down the rabbit hole of looking for similar fasteners to what Toyota produced without ordering onsies and twosies, but that's not exactly concourse material.
I have spent a lot of time putting together the list of OEM fasteners for my 73. The NLA items often can be found from Toyota as a better grade or a bit longer or shorter. I am using overland metric ss for some of the exterior stuff. SOR has a good selection. Some of the odd NLA stuff like the phillips hex head sems and slotted hex head bolts are available aftermarket. Ebay, Amazon, Bell metric. I found the hardest items to match were rubber and nylon washers that are NLA and not able to decipher dimensions from the part number.
There is a separate thread discussing options for replacement hardware here:
I was hoping to keep this thread on-track specifically for PERIOD CORRECT hardware. But as I said in the opening post, I purposely left this thread open as a catch-all, because there will be plenty of time for narrowing things down later. We already have over a half dozen new rabbit holes to explore with the mfg names that Onur provided. 😊
The lawyer in me just can’t help thinking that the mfgrs had to have a list of who made what when for liability purposes.
