Remember, the visor goes between the widow rubber channels and the metal body of the door.
yup, thanks for the reminderRemember, the visor goes between the widow rubber channels and the metal body of the door.
View attachment 3602535View attachment 3602536View attachment 3602537
it's posted up in the faces book at truenorth toyota trucks if you're inclined to dig.
That beats having to pay free dollars for each wheel.who in here is our front axle guru? specifically, front spindle n hub. the reason i ask is, last night i scored a set of 32-11.50 hoosier ATs on a very clean set of aluminum rims which i'd like to run, with 3/4" spacers. yes, i know i'll need the spacers to run those wheels. my query is, will the hubs from '86 to what, '93 mini truck work on my spindles? as they do push the wheel mount surface out by an inch plus on the mini truck solid axle. not done so yet, but i'll be checking if they'll even move the wms. just trying to see if i can run the aluminum rims with out the spacers with those hubs. oh, the score on those, free.95![]()
it don't take much to be smarter than me, so yeah, i'm hopin' they're readingI have no idea if you can run the mini hubs on your spindles. You might have to be the Guinea pig and tell us if it works. There’s bound to be someone smarter than me reading this.
I’m wondering why? Wheels are everywhere and since you had issues with brakes etc just keepwho in here is our front axle guru? specifically, front spindle n hub. the reason i ask is, last night i scored a set of 32-11.50 hoosier ATs on a very clean set of aluminum rims which i'd like to run, with 3/4" spacers. yes, i know i'll need the spacers to run those wheels. my query is, will the hubs from '86 to what, '93 mini truck work on my spindles? as they do push the wheel mount surface out by an inch plus on the mini truck solid axle. not done so yet, but i'll be checking if they'll even move the wms. just trying to see if i can run the aluminum rims with out the spacers with those hubs. oh, the score on those, free.95![]()
I wonder if @cruiseroutfit has any ideas about this setup. He might sell the parts for both axles.done a bit of diggin' this evening in the intardwebs regarding mini truck ifs hubs on 60 spindles. with my limited search abilities it is leading me to believe that the bearings are the same p/n. if that's the case, that's one hurdle overcome. didn't dig into the seal yet, we'll see what that unearths when i do. i've got a set or 2 of the ifs hubs in the stock pile, unfortunately no spare 60 front axle. you know, for testing purposes as i don't want to lay the 60 up for r+d
thank you for confirming that for me kurt79-85 PU/4Runner spindles are the same as 9/75-1/90 4x/5x/6x/7x spindles. So yes, the IFS “wide axle” conversion setups can work on a Land Cruiser axle with the same mods to caliper/rotor relationship, etc
yup, of that i'm aware^^^
in other words, the rotors bolt to the hub, the calipers bolt to the knuckle. Picture what happens when the
rotor moves out an inch but the caliper stays put
that's one way to get the smarter ones to read my ramblingsI wonder if @cruiseroutfit has any ideas about this setup. He might sell the parts for both axles.
The concept has already been done with big brake kits like those from Front Range. The only change that would be necessarythank you for confirming that for me kurt
that's one way to get the smarter ones to read my ramblings![]()
. i have 3 sets of rims which i can use, doesn't bother me they are all 15s. sourcing ifs hubs is no issue, the warchest has 3 pair in it from the days of partin' out mini trucks
. oh yeah, spacers? they're like body lifts.......building blocks n building blocks are for kids
I went bigger brakes because stock wouldn't stop hard enough with the weight of my 60, especially when loaded for a trip. I have a 39 gallon gas tank, 20 gallon water tank, both of my bumpers, slider, roof rack, and drawers. Add a week's gear and additional water and I'm pushing 6500 or more lbs.. New stock brakes wouldn't lock the tires on pavement. It was even worse if I pulled a small expo trailer . There's reason the 60 is only rated for 3500 towing capacity. As for spacers,@lcwizard , i hear you on the bigger brake idea but i've not done anything to make this tractor faster so right now i don't feel i need bigger. also, i'm a cheap fawker n don't want to throw cash out for a nother set of rims. i have 3 sets of rims which i can use, doesn't bother me they are all 15s. sourcing ifs hubs is no issue, the warchest has 3 pair in it from the days of partin' out mini trucks
20 gallon water tank eh? Been brainstorming water tank ideas and now I'm curious...I went bigger brakes because stock wouldn't stop hard enough with the weight of my 60, especially when loaded for a trip. I have a 39 gallon gas tank, 20 gallon water tank, both of my bumpers, slider, roof rack, and drawers. Add a week's gear and additional water and I'm pushing 6500 or more lbs.. New stock brakes wouldn't lock the tires on pavement. It was even worse if I pulled a small expo trailer . There's reason the 60 is only rated for 3500 towing capacity. As for spacers,
I ran the same set on the 60 for 15 years. Since i was running 33x12.50 back then , the tires rubbed badly on the inside of the rear wheel wells. I ran 2" spacers to alleviate that. Granted, most 60s don't see the percentage of off road to street miles that mine does so the tire rubbing isn't as much an issue.
Now I run 80 axles and 35s so the spacers aren't needed. I like the wider stance, whether with wider axles or spacers. You notice it on the off-camber shelf roads in Colorado and Utah
I did the pvc shower on the roof for a while. It’s a cool concept, but I don’t like having that much weight up top. I want to install a reservoir beneath the truck with a heat exchanger in the engine bay and an electric shower pump. I haven’t really thought too deeply about it, though I know it’s totally possible. Especially on a 60 series.20 gallon water tank eh? Been brainstorming water tank ideas and now I'm curious...
