The Diesel Part number thread. NO CHIT CHAT or PARTS # REQUESTS! (5 Viewers)
1990 HDJ-81 Oil, Air, and Fuel filters...
Some of this info may be duplicated...
Just installed new air filter, a WIX 42159 this replaces the "ATEB" installed Toyota 17801-54060 which the the Toyota parts guy says is a 1980's 4-runner part, this filter also has a smaller outside diameter.
The WIX 42159 also replaces the Toyota 17801-68020 which replaced the Toyota 17801-66020.
Fuel Filter Toyota PN is 23303-64010
Oil Filter Toyota PN is 90915-30002, I have been able to get the oil filter at the Toyota dealer in North Vancouver.
Just picked up two new Gates brand alternator / fan belts for the HZJ73.
1HZ / 1HD-T GENERATOR BELT
GATES PART# 70395
Toyota H Diesel Engine
The Toyota Part numbers for the filters are:
Oil- 04152-46011
Fuel- 04234-48012
Air- 23301-30205-71
13B-T vacuum switching valve, 13BT vacuum switching valve
Aftermarket vacuum switching valve I have used on my 13BT.
Old Parker part number is :MKHONBG49A(bought one of these 7-2011 for $42.31 shipped)
replaced by Parker # XM30NBG49A (Bought one of these in 2008 was $39.86)
I mounted the VSV under my dash, rather than in the engine compartment.
1HZ Fan
OEM: 16361-17010
1HZ Fan Clutch
OEM: 16210-17021
24V glow plug
Glow plug for 24V 1PZ, 1HZ, 1HD
19850-58010
Glow Plug for 12V 1PZ, 1HZ, 1HD
19850-64031
HJ60 2H vacuum pump oil inlet hose (banjo fitting at both ends) 90923‑02100
HJ60 2H vacuum pump oil outlet hose (banjo fitting at one end) 90923‑02079; if unavailable, this hose can be made using a length of 3/8" hose and a Parker 34982-14-6 push-lok 14mm banjo fitting available online through MRO Stop. Thanks to jus cruzin for posting the Parker part numbers in the 3b banjo oil fittings thread.
1983 BJ42: Brushes (2) for a 24v alternator from Toyota 27371-54412
The parts guy gave me two numbers for the bearing so I think they switched it up part way through production. Not sure which is which: 90099-10120 and 90099-10137
H, 2H, 12H-T belts at NAPA
Power Steering 22350
Water Pump/Alternator 22434
A/C 9550
Rear Quarter Glass 62711-60330 RH
Newest number
Just ordered the last unit in NA.
1HD-T fuel heater primer assembly.
23301‑17020
heater assembly
23910‑17020
Sorry no pics, maybe some with it can post. NOT available in the US.
BJ74 13B-T, 3B and H55 brackets
13B-T motor mount rubber BJ74. 12361-58031
3B AC Bracket. 146260-4230. Fits on a 13B-T but you have to use a 3B compressor
13B-T Alternator bracket 44448-60060
H55 Transmission rubber Mount 12371-58020
Hz fan/alternator belt-
from Lordco Auto Parts
Dayco (Top cog) # 15395 (39.5'')
My old belts measured out at 40", but were at the end of the adjustment nut, they do make a 40" belt
12HT vacuum alternator O-rings
outer alternator side o-ring Toyota # 90099-14055 $9 CDN today
vacuum pump side o-ring Toyota # 96740-02063 $7 CDN today 9 left in California
1978 BJ40 (12v) with B Motor
Clutch Slave Cylinder
Toyota: 31470-60050
AISIN: CRT-069
Great Nippon Denso supplier: Turbo Diesel and Electric Systems ,Forrest Park Ga. {Atlanta} 1-800-241-4389. Cathy in the parts dept found me two 3B diesel. [Also known as Toyota part #22303347010][ Diaphrams Denso ## 090580-0041 ,for 21.73 Each plus UPS shipped same day
3B Diaphrams
Toyota #2230347010,Wholesale is appx $75.From cruiser Dan. Nippon denso 3090580-0041,same part appx $22 Turbo diesel
& Elestric -1-800-241-4389 Atlanta ga
Just ordered a radiator for my 2h direct from Toyota for under 400. The part number is
16400-68160 if anyone want to contact info for the dealership who ordered it let me know.
