Same idea here.
Please list the part number and it's application on any part that you may have used for your rig in the past.
Stone
[size=+2]PLEASE ONLY POST PART NUMBERS IN THIS THREAD. CHECK PREVIOUS REPLIES TO AVOID DOUBLE-POSTING. IF YOU HAVE QUESTIONS REGARDING PART NUMBERS, PLEASE START ANOTHER THREAD. THIS THREAD WILL BE CLEANED UP OF CHIT-CHAT AND POST NOT OFFERING NEW PART NUMBERS. THANKS.[/SIZE]
[size=+1]B,2B,3B,13B-T OR ANY OTHER B DESIGNATED[/SIZE]
[size=+1]H,2H AND 12H-T ENGINES[/SIZE]
[size=+1]1HZ ENGINES[/SIZE]
[size=+1]1HD-T ENGINES[/SIZE]
Gasket part numbers for the CT-26 turbo (on a 1HD-T) :
[size=+1]2L, 2L-T, 2LTE and LATER VERSIONS OF LIGHT DIESEL[/size]
Stone
NAPA Gold/WIX numbers:
Oil Filter - NGF 1515MP (Cross reference to a Fram PH8A).
Fuel Filter - NGF 3393 (May use NGF 3386 for a 3B).
Air Filter - NGF 2159.
Toyota part numbers:
Thermostat: 90916-03103.
Thermostat Gasket: 16341-56021.
Toyota Part numbers:
Exhaust Manifold Gasket: 17173-58010.
Exhaust Manifold Stud (Long with Torx drive end): 90116-10150.
Exhaust Manifold Stud (Short with plain end): 90116-10149.
Exhaust Manifold Nut: 90179-10010.
3B BJ60
Block Heater C0140-00126-S2 oem
Alt Brushes 12v 021630-0530 Denso
Volt reg 12v IN218 Transpo
Steering Column U-Joints 04371-10011 oem
3B BJ70
delevery valve gasket : 22149-76010
rad cap : 16401-54750
water pump : 16100-59105
PS pump belt : 99343-11510
WP belt : 99343-01195
head gasket kit : 04112-58042
BJ74 13B-T Belts
Alternator: 22474 (NAPA)
Power Steering: 22607 (NAPA)
A/C: 17405 (Goodyear)
3B/13BT waterpump interchangability:
16100-95105
84/11-88/08 3B/13BT
88/08-90/01 13BT
hth's
gb
Air Filter cross over numbers for 2H, 12HT, 3B, 13BT and more...
TRD Oiled Air filter part number is: COTRA-17801-06
K&N oiled Air filter E2440
Toyota paper is 17801-68020 and 60040
Fram air filter CA376
Wix air filter 42159
Napa air filter 2159
Motorcraft air filter FA584R
3B/13 BT Solid clutch fan kit.
16365-18010 Spacer
16365-18010-FA Adapter plate
GB
I found a fuel filter for the 2H, 12HT, 3B, 13BT at Fleetguard the other day
Fleetguard FF5114 (use in place of Toyota 23303-56031)
Fleetguard filter numbers
Oil Filter 3B/13BT LF3313 for the basic and LF3487 for the upgraded filter.
Oil Filter 12HT LF3399
Fuel Filter 13BT/2H/12HT LF5138
Fuel Filter 3B LF5114 (daryl, the 13BT/2H/12HT is a slightly longer filter, but the 3B will work).
Andre...no need to have as a sticky. It can be accessed from the FAQ thread which is the main sticky.
hth's
gb
3B 12V voltage regulator - w/ inc regulator:
OEM : 27700-57060 : ±290$
OEM remanufactured for Toyota by Denso 27700-5760-84 : ±80$
Transpo : IN218 - ±30$ (http://195.125.241.148/cgi-win/product.exe?IN218)
Starter contacts for 3B found at Lordco. Part number from the Lordco invoice as follows:
Starter contacts: Wilson 45-29-6522 less than $10
Plunger: Wilson 45-29-6452 $12
Internal IC Regulator: Wilson 62-29-16029 looks the same but not yet tested (it's my spare) about $70
Primer can be replaced with a Bosch 2 447 010 038 'cause I just did that on my BJ60. This one doesn't require you to loosen it to pump.
2H/12HT filter numbers
Napa Gold Air Filter 2159 (see air filter post below)
Napa Gold Fuel Filter 3393 (Good for 13BT too)
Napa Gold Oil Filter 1627 - Cross from LF3399 and Toyota 15601-68010
gb
Beck/Arnley Air Filter 042-1456
Beck/Arnley Oil Filter 041-8193
gb
Motorcraft air filter FA584RIn my 2H I use the E2443 model ..
Someo of my part numebrs...
ARB Air Locker Long cross shaft for semi-floaters 060205
ARB Air Locker Pinion Thrust Washer 151102
(You don't want to know why I have those numbers!)
-Pinion Large Bearing Koyo ST4090-N need 1 30308 92KA1
30306 92KA1 small bearing
-Inner Axle Koyo 17887(bearing), 17831 (race)
-input Bearing Koyo 6207T6 need two
-Front output Bearing Koyo TR070902
-Rear Output Bearing koyo 30307T2 race 30307J
-Rear Semi floater Axle Bearing Koyo RNU0727. Not available through bearing suppliers, but a Koyo bearing shows up in a Federal Mogul box when purchased through the aftermarket suppliers. Koyo can't even order that bearing!
Timkin front axle bearing numbers
lm104948 bearing
lm104910 race
lm102949 bearing
lm102910 race
-K&N Air Filter #E2440
-Front Output Seal Toyota 90311-48002
-Rear Output Seal Toyota 90311-48003
-Tcase to tranny Seal 90311-78007
- Idler Pulley bearing for York Compressor NSK 6203
fuel filters
Fram P3627
Purolator F54469
Oil Filter -
Purolator L30001
for 2H engine
Kralinator L6
Glow Plugs 6V for 12V Superglow
Toyota 19850-68051
ND 067100-1680 6V
Glow Plugs 14V for 24V Superglow
Toyota 19850-68060
ND 067100-1460 14V
HJ61 12H-T
Master Cylinder:
No Toyota # yet...
Raybestos Lordco #MC39996
NAPA #P9885
Oil filter
Fuel Filter
Brake master cyl for HJ61 1989 ARL
47201 60380 Toyota AUST
Bull said:Oil Filter Warning
for 2H engines oil filter #PH8A aka "8A" as listed above is not reccomended for 2H engines.
Why do I know this? I just popped 2 off my 2H, I called a oil filter tech hotline and they confirmed that the 2H diesel oil pressure exceeds the max oil pressure allowed by the 8A. I put a napa filter part #1627 and it works without issue and is probably twice the size of the 8A
12HT clutch part #s
Courtesy of gb:
Clutch PP: 31210-60100. This will be a North American number and can be had a Toyota. PP crosses with a slew of applications, including 13BT and 1HZ, even though EPC does not say so.
Clutch Disc: 31250-60170. This will be a North American number, and can be had at Toyota. 275mm disc that crosses with the FJ62.
Courtesy of my own research:
Pilot Bearing - 90363-15004 (Koyo 62022)
Release Bearing - 90363-45013 (Koyo RCT52S) (same as the FJ60s)
The Pilot bearing was available at BC bearing but the release bearing was a bit harder to get. It showed as a good number in their system but they said they didn’t know if or when they could get it and how much.
While you are doing the clutch, you might want to check out the rear main seal:
Rear Main - 90311-95002
Rear Main Gasket - 11383-68020
hth's
gb
water pump for 2h
Fenco P1329, (it will come up with a old or deleted number get the parts place to check with fenco direct. they do still supply them under land cruisers, or heavy duty/toyota forklifts)
Full Float axle seal:
CR 13911
Alternator Belt:
Toyota 99343-11095 ($27 CAD)
Power Steering Belt:
Toyota 90916-02153 ($17 CAD)
A/C Belt:
Toyota 99332-01395 ($21 CAD)
HJ45 "H" Diesel
Air Filter: Carquest 87093
Fuel Filter: Napa Gold 3166
1HZ / 1HDT
Oil filter 90915-30002/90915-03006 or 15600-41010
Fuel filter (primary) 23303-64010
Dave
STP SA376, also fits 1HD-T, US$12 at Autozone in Maine
Pulled from a Jimmy B post.....................
Stock 1HZ Toyota fuel filter prt #23303-64010
For aftermarket the following part numbers
Donaldson P550385
Baldwin BF7535
Luberfiner G2920
Wix 33138
For 1HZ engine oil filter- toyota prt #90915-30002
Donaldson P550597
Baldwin BD7029
Luberfiner LFP5971
Check with the local toyota dealer on the oil filter,locally it was the cheapest over the counter price about $26.00
James...
04May2005 (UTC -8)
Dave, would you believe that my 1995 FZJ-80 (Arab-spec) had a 1HD-T engine oil filter on it when I purchased it? I couldn't believe it when I saw it, but it seemed to have no problems --no oil leaks, no loss in oil pressure, no problem.
I checked the o-ring on both the 2UZ-FE/1FZ-FE oil filter and the metal part where it seals the 1FZ-FE engine, and it's identical in size and thread to the 1HD-T oil filter.
Changed it to the smaller 2UZ-FE/1FZ-FE oil filter of course, but I do wonder what would have been the benefits/issues/troubles if I kept that 1HD-T engine oil filter in there?
No idea, but the 15600-41010 is visibly larger than the other. Maybe it is meant for different markets with different driving conditions? That is good info, Drexx, now we know the 1HZ/1HDT filter fits the 1FZFE and the 2UZFE!
Dave
Tried the 15600-41010 on my 1HD-T, no fit, left me in a right pickle. Gonna order the 30002 from Toyota tomorrow.
70sguy said:Gasket, Turbo oil inlet 15471-58010
Gasket, water bypass 16347-42020
Gasket, turbo to ex manifold 17278-88380
Gasket, turbine outlet elbow 17279-17020
The second two are steel and probably fine just fine to reuse.
The first two may come with your RB turbo but if you want a set to be sure. The first 3 are good North American Toyota numbers.
2L-T parts number:
Air Filter: 17801-54080
Diesel-Filter: 23303-64010
Oil Filter: 15600-41010 (MANN FILTER: W940/81)
Timing Belt (TDLER): 13505-54010
Timing Belt (belt): 13568-59027
Cylinder KIT (clutch): 04313-12030
