The Diesel Part number thread. NO CHIT CHAT or PARTS # REQUESTS!
1HD-T ACL Engine Bearings in the US
For those who have been looking for an independent source of engine bearings for the 1HD-T, Hastings Manufacturing in Michigan (800-847-5521) has the ACL bearings in stock. They will sell direct retail if you have a credit card. The distributor in Canada will not (they only sell to registered dealers).
The Connecting Rod Bearings (6B8396 - STD) are $35.83
The Main Bearings (7M8397) are $50.62.
UPS ground shipping in the US is, I'm told, about $5.00.
Prices as of today, May 07, 2007
Sheldon: Sorry for being so harsh on you about your pricing. With everything you include (bearings, bolts and plastigauge), considering you must be getting them abroad as well, CDN$105 is good price for the whole kit.
Keep up the good work! :)
Chris
I'm pretty sure this has not been listed yet, if so, please delete.
24Volt brake light/ running light bulb from Cat/Finning dealer, $4.40 Cdn each Part #: 9X4492
I'm sure they also have a lot of 24Volt stuff, especially bulbs, since some of their equipment is 24.
Cheers,
Deny
1979 BJ40 fitted with B series 2977cc diesel engine
Here are some of the numbers I have for regularly-purchased items:
Air Filter: Ryco A340, FRAM CA376, Unifilter UC210-152S
Oil filter:Ryco Z9 (or Z115), AC PF2, Highway 51016, FRAM PH8A
Fuel filter: Ryco Z127 (or Z169 or Z169A), FRAM P4178 but some of these filters are taller than others which is why I moved the filter location from the engine to the side of the battery-support. - For easier changing and to allow the taller (more readily available and cheaper) filters to be fitted.
Radiator top hose: CH1328
Radiator bottom hose: CH1336
Brake and Clutch pedal pads: Silentruba A1308
Wheel bearing & seal kits for each wheel (full floating): SAECO TF002
Injector pump diaphragm: DENSO 090580-0041
The charge lamp relay for Toyota Part 2779013010 (mentioned above) cross-references to Napa Auto Parts Part : ECHAR250 and is listed as "Charge Lamp Relay" or "Accessory Relay" or "Instrument Relay". It is Mfg. by 'Echlin Products'.
It retails for a whopping $86.00 (USD as of 10/2007).
www.napaonline.com
3B & 13B-T maybe 2H Alternator Replacement
After a long hard search I found a Alternator from a 84-85 Toyota pick-up DLX with a 2.4L diesel it's the same exact alternator for 3B and 13B-T. The only thing you need to do is replace the new alternator pulley with the pulley from your old alternator and everything else plugs in.
I took a look at the 3B & 2H manuals and Toyota LC micro fiche they look the same. Take a look at the Napa Auto Parts and Rock Auto Parts web-sites.
Alternator is from a:
84-85 Toyota Pick-up DLX
2.4L Diesel
12 volt system
55-60 amp
Napa Auto Parts, does not come with vacuum pump
#14675 or Ray #138292
On the Napa alternators I went with the Premium Alternators. These have free replacement warranty as long as you keep your invoice. Take note, Napa no longer carries the Beck/Arnley alternators
Napa Premium Alternators Prices:
#14675 $170
Ray #138292 $164
Rock Auto Parts, comes with vacuum pump
Beck/Arnley #1860609
Alternator to Vacuum Pump O-Ring
new O ring for mounting your vacuum pump is 55mm x 2mm you can get this O-ring at a hydraulic shop.
Hope this helps
12HT A/C Compressor Bearing
I took my A/C Pulley off the other day to check the A/C Bearing. It was stamped: Koyo 83A55184.
EPC shows Toyota # 90099-10133. So theoretically these numbers should cross over. I didn't end up replacing mine (it was fine, the pulley/clutch backside just needed a good cleaning) so I can't say 100%
Rear Slider Window Seals, Aussie Spec '82 HJ60, etc.
Source: Scott's Old Auto Rubber, Melbourne AU
http//:www.scottsoldautorubber.com.au
Part Number: 351-551, about $35 US.
This is only the inner seal that the glass sits on and slides on. You'll have to figure out what to do for the outer seal yourself, but that's much less specific. The ordering system is still in the last century, so you have to call them with your credit card # or fax it to them, or wire them money, but once I did that, it took less than one week to have it delivered stateside, and looks to be of excellent quality. They have lots of other similar products for old Toyotas, Rovers, etc.
Various Timing belt stuff for HD-T and HZ. all toyota parts numbers.
11328-17010 timing belt cover gasket
13568-19065 timing belt hd-t
90109-06046 bolts ( x3)
90210-08019 washers ( x3)
90468-05034 clips ( x4)
90507-27003 tension spring
side note: cdan can get most of the parts-- not the cover, maybe not the gasket, but the rest it seems that yes, he can.
