The Diesel Part number thread. NO CHIT CHAT or PARTS # REQUESTS!
3B water pump aftermarket by NPW. Uses the Toyota part number (16100-59105) Altrom Group number 152-9210 works on 2B, 3B, 13B engines BJ-41-42-44-46-60-61-70-73-74.
Other numbers on the box BB-20-30 made in Japan.
3B belts (non AC with Power steering)
Gates TR22607
Gates TR22474
Looks like front JDM 15" and N.A 16" rotors, and calipers are interchangeable because I just changed mine.
Ordered the Lexus pads only to discover that the supplier shipped three rather than four brake pads...
not to worry I had others laying around somewhere. These are bigger and and thicker, now I can finally lock the front end up.
Ideally you will use a rotor like pictured below or machine the ridge on your exixting rotors if these pads are to big.
I do have part numbers and will forward them once back off the road.
IH8MUD.com - View Single Post - 93 80 Beater.
04465-60250 bigger and thicker than Lexus pads
For the HDJ 80 94 Turbo 12 valve model and are all OEM numbers, I have only posted the parts I have actually fitted without issues i.e they are correct.
Battery T28800-YZZJA
Battery T28800-YZZAF
I am unsure which is left or right, the EPC shows 28800 for both, that is wrong as they are handed.
Alternator adjuster bracket (slotted part) T16381-17010
Bush (that the adjuster bolt goes into) T16385-17010
Adjuster bolt T90119-08493
Oil filter 90915 300028T
Fuel filter 2330364010
Top hose 1657217010
Bottom hose 1657117010
Radiator cap 1640154750
Big end bolts 1326517010
Spindle bush where birf enters spindle 9038133001 this is the new number, old was 43211R
Top radiator bolts also known by Toyota as 'collars' 1654961020
The correct flanged nuts for the top radiator bolts are 9017908025
Diesel tank gauge sender 8332069085 this is for the sender i.e. float/low level light
halfshaft 'O' ring for front axle shaft/housing 9031035010
regards
Dave
1977 BJ40 From Italy Rear Brake Drums
1977 BJ40 from italy rear brake drums.
This BJ40 has front disc and rear drums.
Rear Drum Part numbers
Centric Part number
122.44019
or Beck Arnley
080-0521
More 3B belts and xrefs:
Water/Fan/Alt:
OEM: 99343-01195
Gates: TR22474
PS:
OEM: 99343-11510
Gates: 17X1500LI
AC:
OEM: 99322-01030
Gates: 9412, 9412HD
H55 Split Case Output shaft, without parking brake on back of split case: 36231-60021
H55 Split case output shaft, with parking brake drum on back of split case :36231-60031
Retaining nut for split case :90179-22005
Bearing next to low gear on Output shaft in Split case :toyota #90366-35053. Koyo does NOT cross reference this bearing. The one that is close will NOT work.
slave cylinder info
BJ40/42 clutch slave cylinder: 31470-60110
Slave return spring: 90506-16475
3B timing cover seal aka front main seal
Timing cover seal (aka front main seal) for August 1986 CDN BJ70 with 3B as of August 2010 at N.American toyota dealer: 90311-50013 Seal, Type T Oil. $12.00 USD.
OEM 'O' ring or seal for speedometer electric drive where it enters the transfer box
96711-24030
Bronze bush/flange fitted where the birf enters the spindle OEM 90381-33001
Both for 1994 HDJ80 4.2 TD Manual, factory lockers....but I think they will fit cars painted a different colour.
regards
Dave
3B and 13BT head/intake/exhaust gaskets
From [thread=117574]this thread[/thread] on 3B and 13BT head/intake/exhaust gaskets:
11115-58110 is the 3B/13BT head gasket up to 88/08 and then just the 13BT until 90/01. The 3B after 88/08 is 11115-58080.
3B/13BT Intake manifold gasket is 17172-56022, which crosses to 17171-56010, which works for both to 90/01.
3B/13BT Exhaust manifold gasket is 17173-58010 for both up to 88/08. The 3B splits off after 88/08 to 17173-56040, and the 13BT stays with the 58010 to 90/01.
1987.BJ70.Canadian model.
Radiator. #16400-58310
Muffler with Tailpipe. #17430-58190
Hood support rod. Nylon block. #53455-14020
24v electrical block under hood for accessories. #82670‑90K00
Original converter 24v to 12v for Radio. #86206-90K00
Originally Posted by FJBen
HJ45 "H" Diesel
Air Filter: Carquest 87093
Fuel Filter: Napa Gold 3166
I don't know if NAPA changed the item or if my H is different but the 3166 will NOT work on my HJ45. FWIW
1HZ to H55F Bell Housing
31111-60230
Credit to Petzel for the number and
Beno for checking it
Various Timing belt stuff for HD-T and HZ. all toyota parts numbers.
11328-17010 timing belt cover gasket [[AVAILABLE FROM TOYOTA USA]
13568-19065 timing belt hd-t [AVAILABLE FROM TOYOTA USA]
90109-06046 bolts ( x3)
90210-08019 washers ( x3)
90468-05034 clips ( x4)
90507-27003 tension spring
side note: cdan can get most of the parts-- not the cover, maybe not the gasket, but the rest it seems that yes, he can.
Some updates in bold above.
HDJ81 Alternator.
One from a similar vintage Supra will fit and has 80 Amps rather than 60 Amp capacity. You'll have to swap the serpentine pulley with your double v pulley. Mounting and wiring is identical to OEM.
UK spec diesel cars have 80 amp stock.
regards
Dave
I am converting my 24v HJ60 to 12v. I am looking for the part numbers or replacement options for the Starter and Glow Relays. These are the numbers for the 24v ones in my truck that I want equivalent 12v ones for:
Starter relay
28300-56020
056700-7100
Glow relay
28610-54180
056700-5920
Ideas?
Excel Program with sequential numbers via Gibralter
Hopefully we can fill in the blanks adding numbers, descriptions and cross reference numbers.
Who knows maybe we can even include vendor links.
Stole this from Gibraltar Toyota seeing that it is availbale globally.
What helps is the "edit" find option.
HomePage
