SOLD Texas 1976 FJ40 (PS and AC) 2F - Mustard
Year
1976
  1. 40 Series
Houston, Texas United States
Mileage
30383
Color
yellow
1976 Mustard FJ40 for Sale - Houston Texas
$38,800.00
1976 FJ40 30,410 shown - TMU (driving a little)
4Plus bumpers front and rear - rear custom dual swing (arm included w/sale but not mounted)
Warn 8274 mounted on front with controller
6 Steel 15” wheels with BFG Mud Terrains 33x10.5
Chrome caps
NOS 1976 correct, non CA carb
Mini Truck power steering upgrade - saginaw pump
Vintage AC - blows cold
D.U.I. Toyota specific HEI distributor and wires
Header
Brake pads and rotors done
Second fuel tank switched on the dash - Ford saddle tank solenoids
SOR springs/lif
Replaced spring bushings
Ubolt skid plates
OME shocks
New mater cylinder and pressure switches (Georg)
Valley Hybrids double seal upgrade on output shaft (ebrake) @orangefj45
Northstar AMG31M
Cowl body seam resealed and painted (dry feet)
Clairon radio w/Sirris/XM remote antenna
Original rubber mat included as well - used
Cityracer rubber mat - new
Below work completed 4/4/2021 by Northwest Design and Fabrication (Steve); @samc2447
Extreme Aire High Output compressor with additional chuck in rear for air, fittings and bracket @orangefj45
ARB lockers installed
4 speed rebuilt Japanese bearings
4.11 gears rebuilt
Rebuilt Knuckles with Japanese trunion and wheel bearings
555 Japanese TRE kit installed
Rebuilt center steering arm
AISIN Clutch kit installed
Flywheel refinished
Rebuilt transfer case Japanese bearings
Rebuilt e brake
Rear main seal
Oil pan gasket
I purchased this FJ40 out of Tuscan AZ a couple years ago, @FARMAN33 and I made a three day run from Houston and back. Truck is in Houston but spent weeks some summers in CO (Aspen, Carbondale and Crested Butte area). Trails like Montezuma, Taylor Creek and Pearl with @HemiAlex @samc2447 @FARMAN33 @reddog90 Been thru 13,000 ft with carb after timing is advanced and with dual lockers (almost never needed), she can’t be stopped. Not a garage queen, looks painted with a restore (replaced cut wheel wells in quarters) in the past per PO and condition of truck. Only one spot of rust that I have included in pics, hasn’t changed in the years I have owned, pass rear above that damn inner brace. One or two small scares from a trail, also included in pics. All locks work and if you know my trucks just about zero rattles (amazing for a 40). Always OEM when available, hubs engaged and driven monthly per Owners Manual. Pretty damn clean truck.
Look forward to talking - don't need help selling and PLEASE clear this with your significant other if you haven't before reaching out. Thank you.
The truck has pedigree and has proven it self.
It will be missed, but it’s a turn key rig.
Yup, this is a real issue. Had 2 guys back out of deals last minute blaming the wife. Lots of wasted effort.
Beautiful 40 for sure! Love the color!
Wife left in 2010 after the 77th Land Cruiser. Pushing 300 these days :)
SOLD
